schmitty 66 Posted December 15, 2016 Posted December 15, 2016 I have ripped We're the Millers Blu-Ray to MKV, with extras and an Extended Cut. The extras and extended cut are not being detected as an alternate version or extras, they are being identified as individual movies. I have followed the instructions in the wiki, to no avail. The file structure is as follows: \SERVER\Movies\We're the Millers (2013).H264-DTS.BluRay-1080p\ We're the Millers (2013).H264-DTS.BluRay-1080p.mkv We're the Millers (2013) - Extended Cut.H264-DTS.BluRay-1080p.mkv extras\ deleted-scenes.mkv don't-suck-the-venom.mkv extreme-aniston.mkv gags&more-outtakes.mkv getting-out-of-a-sticky-situation.mkv i-am-pablo-chacon.mkv intro.mkv livin'-it-up-with-brad.mkv outtakes.mkv road-trippin'-with-the-millers.mkv rollin'-in-the-rv.mkv the-miller-makeovers.mkv when-paranoia-sets-in.mkv
codenamegamma 4 Posted December 16, 2016 Posted December 16, 2016 (edited) i dont have a problem but my folder is named "Specials" instead of "extras" and it shows up in the web ui as far as alternate versions, i have them stored in the Specials older as well, and i guess thats suppose to work, but for clients like Kodi they cant be played back since they wont show up. i guess no ones going to be watching The Rouge Cut, of X-Men Days of Future Past anytime soon. Edited December 16, 2016 by codenamegamma
Jack Burton 98 Posted December 16, 2016 Posted December 16, 2016 I don't think Emby will discern between different cuts of movies. What I usually do (say for a regular release and a directors cut), is just create 2 folders for the same movie. Emby will then have 2 instances of said movie, and I change the poster for the directors cut to a poster that actually says directors cut. For example, in my movies view I have 2 "movies" of Watchmen. One has the regular poster, and the other has the Ultimate Cut poster. As for the extras issue, I only have 1 or 2 movies with extras, and they work for me, but my folder is labelled Specials. Hope that helps 1
Abobader 3485 Posted December 16, 2016 Posted December 16, 2016 Good day, This new/clean install of emby dev, and it working here as it should, naming the sub-folder should be either "extras" or "Extras" will work: My best
Deathsquirrel 745 Posted December 16, 2016 Posted December 16, 2016 I don't think Emby will discern between different cuts of movies. What I usually do (say for a regular release and a directors cut), is just create 2 folders for the same movie. Emby will then have 2 instances of said movie, and I change the poster for the directors cut to a poster that actually says directors cut. For example, in my movies view I have 2 "movies" of Watchmen. One has the regular poster, and the other has the Ultimate Cut poster. As for the extras issue, I only have 1 or 2 movies with extras, and they work for me, but my folder is labelled Specials. Hope that helps This is all correct in my experience. To add to it, you can then put the two different movies in a collection together. That keeps them to one entry in the main UI.
