bric 34 Posted December 13, 2016 Posted December 13, 2016 (edited) I like the filter: it's very useful to be able to narrow your choice of movies. Is there a way to use an AND instead of an OR in selecting genres? Example: my younger daughter likes comedies. Animated comedies are good. Action comedies generally fine. Dramatic comedy? -- Not usually. So something like: comedy OR (comedy AND (animation OR action)) or even: comedy NOT (drama AND horror) Is there an 'advanced filter' somewhere that I'm not aware of? If not, I'd suggest it as a feature though I appreciate it might clutter the gui. Although with a bit of javascript you could make the checkboxes in the filter selection go 'checkmark', 'X', 'clear'. That would at least allow my second case. Edited December 13, 2016 by bric
