maegibbons 1287 Posted December 13, 2016 Posted December 13, 2016 Hi I have an HDhomerun CONNECT tuner and a Qbox running Android TV connected to the telly. Some of the Channels are displaying in the wrong aspect ratio namely 4:3 when they should be displaying in 16:9. The same channels display fine on my Android phone and Chromecast. It is just with the Android TV app that the ratio is wrong. Tell me what i can give you to help and/or is there any way to force aspect ratio? KR's Mark.
mastrmind11 722 Posted December 13, 2016 Posted December 13, 2016 Hi I have an HDhomerun CONNECT tuner and a Qbox running Android TV connected to the telly. Some of the Channels are displaying in the wrong aspect ratio namely 4:3 when they should be displaying in 16:9. The same channels display fine on my Android phone and Chromecast. It is just with the Android TV app that the ratio is wrong. Tell me what i can give you to help and/or is there any way to force aspect ratio? KR's Mark. Are you on the beta channel? https://emby.media/community/index.php?/topic/42371-nvidia-shield-playing-video-at-43-instead-of-169/
maegibbons 1287 Posted December 13, 2016 Author Posted December 13, 2016 Hi No I am not @@ebr. I tried the beta first actually BUT got absolutely no display at all when playing anything. So i had to revoke membership so i could get stable version which displays ok just some channels wrong aspect. KR's Mark
ebr 16337 Posted December 13, 2016 Posted December 13, 2016 @@maegibbons Can you please go back to the beta and then explain exactly what issue you are having along with logs? How to Report a Problem The beta is about to go stable so, if we don't figure out what your issue is, you won't have much recourse .
maegibbons 1287 Posted December 13, 2016 Author Posted December 13, 2016 @@maegibbons Can you please go back to the beta and then explain exactly what issue you are having along with logs? How to Report a Problem The beta is about to go stable so, if we don't figure out what your issue is, you won't have much recourse . Ok - will do. It will be tomorrow night or Thursday. Kr's Mark
maegibbons 1287 Posted December 13, 2016 Author Posted December 13, 2016 @ebr. Ok i downloaded the beta again and confirm what I found Previously. When I select any Video media whether it be LiveTV, Movies or Recordings after the title appears at the bottom and spinning circle i get sound and a blank/black screen. I can bring up the OSD go to i and say yes to Playback issues. It restarts but still with no video. Do it again and it come back with "Too many errors" I will follow your link tomorrow with regards to providing logs etc. KR's Mark
Luke 42244 Posted December 13, 2016 Posted December 13, 2016 Do you have refresh rate switching enabled?
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 Hi @Luke @ebr - not sure where that is. Anyway here are the logs and a bit more info. This only happens on transcoded/remux media. When its direct play with no ffmpeg in the loop the videos show fine. Hope you get some info from the attached logs. I will try and turn the debug stuff on the app as well. KR's Mark server-nodisplay.txt ffmpeg-transcode-2cce11a1-df85-4383-ba80-1400af54a1c2.txt ffmpeg-transcode-69af5420-4416-4df3-965a-485c520b828e.txt ffmpeg-remux-a6818daa-6fcf-4ea8-b26d-0aa6ca1e38c4.txt
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 FYI It appears that no live tv streams will play directly from the HDhomerum tuner. Only recorded content that does not need transcoding plays Basically, anything that needs transcoding results in blank video. Mark
ebr 16337 Posted December 14, 2016 Posted December 14, 2016 Luke - is that not a really old version of ffmpeg...?
Luke 42244 Posted December 14, 2016 Posted December 14, 2016 @@maegibbons i am discussing options to address this issue with Ebr.
ebr 16337 Posted December 14, 2016 Posted December 14, 2016 Can you please go through the process of playing something with the problem and then hitting the "!" button until it ultimately fails and then send a log from the app. After that, come here and tell me what you played and the name of the Emby user that was logged in. Thanks.
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 Hi Just done it. Sent logs twice. First was Live TV Channel 3 ITV Dickinsons Real Deal Second was a Movie. Independance Day Resurgence. User is emby KR's Mark
ebr 16337 Posted December 14, 2016 Posted December 14, 2016 What is this device you are running on? Is it a true Android TV device?
ebr 16337 Posted December 14, 2016 Posted December 14, 2016 The first thing to do is set the Audio Mode in the settings to 'Direct'. Then, for Live TV, also check the boxes to allow using VLC for Live TV and for direct streaming it.
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 No it is a AMlogic Qbox Do I have to install vlc seperately? Krs Mark
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 Turning on vlc made livetv work ok but movies and recording wont play if transcoded.
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 (edited) @ebr If i switch on direct audio my IPTV streams have no sound. Edited December 14, 2016 by maegibbons
maegibbons 1287 Posted December 14, 2016 Author Posted December 14, 2016 (edited) Deleted - Wrong Thread Edited December 15, 2016 by maegibbons
maegibbons 1287 Posted December 17, 2016 Author Posted December 17, 2016 Hi @Luke @ebr - any update on this? The beta is useless for me as is and i will need to revert to stable to continue using emby. What changed from stable to beta to have caused this issue? Stable worked ok apart from aspect ratio issues which was the original subject. KR's mark
ebr 16337 Posted December 17, 2016 Posted December 17, 2016 I needed to get the release out to the general public before I could do anything else on this. Your issue is related to the rare client device and/or server ffmpeg version. I will try to put up a beta today to see if it will address this for you.
maegibbons 1287 Posted December 17, 2016 Author Posted December 17, 2016 (edited) @ebr ok, thank you ffmpeg is the version that is shipped with 16.04. I upgraded from 14.04 because I was having problems with version 3.2.1 which was recommended in a link on this board somewhere. If you want me to try a specific version of ffmpeg which runs on 16.04 please provide a link and i will install. Obviously the version i am currently running was working ok with previous stable. Krs Mark Edited December 17, 2016 by maegibbons
Luke 42244 Posted December 17, 2016 Posted December 17, 2016 If it was working with previous stable then that's fine.
ebr 16337 Posted December 17, 2016 Posted December 17, 2016 You should have access to 1.3.11 in beta now. If you can try with that please let us know how it goes.
maegibbons 1287 Posted December 17, 2016 Author Posted December 17, 2016 @ebr a quick update. I have updated to latest beta and confirm that it is better on initial testing - so thank you for your work. On quick testing when using VLC all SD TV channels work ok from homerun and most IPTV do as well. When not using VLC screen is still blank. Most recordings are also playing but aspect ratio on a few are wrong. Let me play some more over next 24/48 hours to isolate problem areas. Many Thanks once again KR's Mark
