NemesisZeRo 7 Posted December 13, 2016 Posted December 13, 2016 When I'm running a VPN, I only have a few ports I can open, so I'm wondering which port the emby connect uses to communicate to me and what port the user connects to. I'm wondering since I can specify 2 different ports in the emby server, http and https (I would prefer https), which one is used (only got I port to spare, and the VPN don't allow ports so low as 8000 series) [sent from the black box in the wall]
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 You can set Emby to use any available port (Dashboard-Advanced-Hosting). Are you trying to have your user connect through the vpn or have them connect directly via your WAN address? Knowing the vpn address will be your issue since it will constantly change. Currently vpns play havoc with LAN and WAN address reporting in Emby most users end up setting the LAN and WAN address via the same page. And connect via there WAN address.
NemesisZeRo 7 Posted December 13, 2016 Author Posted December 13, 2016 (edited) You can set Emby to use any available port (Dashboard-Advanced-Hosting). Are you trying to have your user connect through the vpn or have them connect directly via your WAN address? Knowing the vpn address will be your issue since it will constantly change. Currently vpns play havoc with LAN and WAN address reporting in Emby most users end up setting the LAN and WAN address via the same page. And connect via there WAN address. I use a VPN to pass by the ISPs "all incoming ports closed" policy, so when I'm using emby connect, I was wondering if they refer the users to the http or https port.. I won't be abel to use the standard ports, and I only want to use 1 incoming port.. I'm currently not having any issue with wan/LAN problem with my VPN..(it's a hardwired box) [sent from the black box in the wall] Edited December 13, 2016 by NemesisZeRo
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 You can use either http or https via Connect. As LAN/WAN problem does the Dashboard show your vpn address or your proper LAN and WAN address?
NemesisZeRo 7 Posted December 13, 2016 Author Posted December 13, 2016 VPN and LAN [sent from the black box in the wall]
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 The all you should have to do is select whether you are going to use http or https and set your port in Hosting.
NemesisZeRo 7 Posted December 13, 2016 Author Posted December 13, 2016 Actually if I only open the https port, will anybody that tries to connect thru emby connect, be connected to the https port, or will it fail because of the http port is closed? [sent from the black box in the wall]
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 I believe they will have to use https://app.emby.media.
NemesisZeRo 7 Posted December 13, 2016 Author Posted December 13, 2016 I forgot to mention that all users use the emby app on Android. Does that one connect to the https or http by default? [sent from the black box in the wall]
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 Report https as external address If enabled, the server will report an https url to Emby apps as it's external address. In hosting enable this option. That should do it.
NemesisZeRo 7 Posted December 13, 2016 Author Posted December 13, 2016 Report https as external address If enabled, the server will report an https url to Emby apps as it's external address. In hosting enable this option. That should do it.Thanks [sent from the black box in the wall]
