secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 how can I save my ebay users access user and pass and restore everything like new?
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 (edited) how can I save my ebay users access user and pass and restore everything like new? Not 100% positive but "Server Configuration Backup" plugin should backup all the information you need. After you make a backup click on the restore to see the options, to see if it captured everything you need. Edited December 13, 2016 by Happy2Play
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 So I take off all your content?
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 I did it that way, but no result is still the same
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 I also made an annual donation because I sembravaun good service I would kindly help how to restore it all over again, and save users thanks
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 (edited) have to uninstall the program and install? then enter the Backup and enable all registered users?I confirmed that it works? Edited December 13, 2016 by secagratis
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 I don't see users there. Are all your users guests? @@Luke will have to comment on guest accounts.
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 @@secagratis, you don't need to uninstall. you're fine where you are. what is the issue you are having now? is it just errors in the log or is the library scan not completing?
secagratis 21 Posted December 14, 2016 Author Posted December 14, 2016 solved by removing all folders by installing the new beta
