Luke 42288 Posted December 12, 2016 Posted December 12, 2016 Hi, please try removing your plugins and seeing if the issue persists. thanks.
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 You still need to resolve or disable "Auto Organize". Line 3843: 2016-12-12 23:52:22.0378 Info App: Sorting file D:\SerieTV\Film\Film\Serietv\La Famiglia Addams\La famiglia Addams - 1x05 - L'albero genealogico degli Addams.mkv to new path D:\SerieTV\Film\Film\Serietv\La Famiglia Addams\La famiglia Addams - 1x05 - L'albero genealogico degli Addams.mkv I doubt Library scan will ever finish do to Auto Organizer trying to move stuff in place.
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 I removed the TV series folder and continues to look for. I tried to rename and locks the same cause does not find the folder series TV
Luke 42288 Posted December 12, 2016 Posted December 12, 2016 I removed the TV series folder and continues to look for. I tried to rename and locks the same cause does not find the folder series TV Can you please describe in more detail what you tried to do? Please attach the emby server log. thanks.
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 What is your Auto Organize "Watch Folder" set to? How are your libraries path setup? Are these the same folders? Line 481: 2016-12-12 23:51:58.9611 Info LibraryMonitor: Unable to add directory watcher for D:\SerieTV\Film\Film\Serietv. It already exists in the dictionary. Line 489: 2016-12-12 23:51:58.9611 Info LibraryMonitor: Unable to add directory watcher for \\xxx.xxx.xx.xxx\teampremium\SerieTV. It already exists in the dictionary.
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 removed the folder D: \ SerieTV \ Movies \ Movies \ SerieTV \ by emby of libreiria but it keeps giving me the same eoorre server-63617186957.txt
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 @@secagratisDid you see my post above #30.
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 What is your Auto Organize "Watch Folder" set to? How are your libraries path setup? Are these the same folders? Line 481: 2016-12-12 23:51:58.9611 Info LibraryMonitor: Unable to add directory watcher for D:\SerieTV\Film\Film\Serietv. It already exists in the dictionary. Line 489: 2016-12-12 23:51:58.9611 Info LibraryMonitor: Unable to add directory watcher for \\xxx.xxx.xx.xxx\teampremium\SerieTV. It already exists in the dictionary. as you see I removed the folder tv series from emby but continues to give me errrore and tries the same folder
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 Please try the next beta. I am just going to update auto-organize so that he will never be able to get into the situation that he's in now. thanks.
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 you removed it from the library but you still have it in auto-organize.
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 TV series as removed from emby but continues to remain
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 That could just be an issue with the beta. i will test it thanks. try running a library scan and/or restarting the server. thanks.
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 sorry but I'm Italian English use the translator
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 Ok thanks. That could just be an issue with the beta. i will test it thanks. try running a library scan and/or restarting the server. thanks.
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 Now even by mistake on the external server I have no more words does not know anymore what to do 2016-12-13 01:36:34.5460 Error LibraryMonitor: Error watching path: \\163.172.48.86\teampremium\Film3D *** Error Report *** Version: 3.1.253.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.ArgumentException: Nome di directory \\xxx.172.48.86\teampremium\Film3D non valido. in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() System.ArgumentException in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() server-63617189436.txt
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 You've added a path to library setup that is no longer valid \\163.172.48.86\teampremium\Film3D
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 You've added a path to library setup that is no longer valid \\163.172.48.86\teampremium\Film3D I understand but if you miss that folder can not block the scanzione this is a problem you have to solve emby give him a command to skip this error
Luke 42288 Posted December 13, 2016 Posted December 13, 2016 It does skip over it. It records the error into the log and skips over it.
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 \\163.172.48.86\teampremium\Film3D this server I removed from the library BUT CONTINUE TO GO OUT 2016-12-13 01:26:02.0951 Error LibraryMonitor: Error watching path: \\163.172.48.86\teampremium\Film3D *** Error Report *** Version: 3.1.253.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.ArgumentException: Nome di directory \\163.172.48.86\teampremium\Film3D non valido. in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() System.ArgumentException in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0()
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 NOW SCAN remains at 5 and not going more forward at least it would not start the match before But I can not write all over again libraries without deleting users access data?
Happy2Play 9814 Posted December 13, 2016 Posted December 13, 2016 You remove all 8 library paths pointing to that server?
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 I removed all libraries now we see that error comes out I can no longer
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 azzzzzzzzzzzzzzzz server-63617191809.txt
secagratis 21 Posted December 13, 2016 Author Posted December 13, 2016 It can not be a thing I have taken away all 2016-12-13 02:15:20.9203 Error LibraryMonitor: Error watching path: \\163.172.48.86\teampremium\DVD *** Error Report *** Version: 3.1.253.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.ArgumentException: Nome di directory \\163.172.48.86\teampremium\DVD non valido. in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0() System.ArgumentException in System.IO.FileSystemWatcher..ctor(String path, String filter) in Emby.Server.Core.IO.LibraryMonitor.<>c__DisplayClass38_0.<StartWatchingPath>b__0()
