secagratis 21 Posted December 11, 2016 Posted December 11, 2016 (edited) server-63617069080.txt Edited December 11, 2016 by secagratis
Luke 42288 Posted December 11, 2016 Posted December 11, 2016 Hi there, can you please describe your problem in more detail? thanks !
secagratis 21 Posted December 11, 2016 Author Posted December 11, 2016 not finalize scanning remains 0
Luke 42288 Posted December 11, 2016 Posted December 11, 2016 Have you tried waiting patiently? Try stopping the organize media task.
Luke 42288 Posted December 11, 2016 Posted December 11, 2016 Your log is also showing a lot of file system errors 2016-12-11 16:10:02.4954 Error App: Failed to move file from D:\SerieTV\Film\Film\Serietv\Ghost Whisperer\Ghost Whisperer - 5x09 - Smarriti Nelle Ombre.mkv to D:\SerieTV\Film\Film\Serietv\Ghost Whisperer\Ghost Whisperer - 5x09 - Smarriti Nelle Ombre.mkv: Il processo non pucedere al file 'D:\SerieTV\Film\Film\Serietv\Ghost Whisperer\Ghost Whisperer - 5x09 - Smarriti Nelle Ombre.mkv' perch顨 in uso da un altro processo. Application Path: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Il processo non pucedere al file 'D:\SerieTV\Film\Film\Serietv\Ghost Whisperer\Ghost Whisperer - 5x09 - Smarriti Nelle Ombre.mkv' perch顨 in uso da un altro processo. System.IO.IOException This could be affecting the library scan.
secagratis 21 Posted December 11, 2016 Author Posted December 11, 2016 I already deleted other TV series but it is not running anywhere as ever from this problem?
AvengersFan 10 Posted December 12, 2016 Posted December 12, 2016 I appear to be having the same issue. For reasons unknown to me my Library scan seems to stop at 37.1%. I have reinstalled EMBY over the top of the previous installation and rebooted but I still seem to be stuck. I have attached the log and a screen shot of the scan along with an exert below of one of the errors I am getting. Any assistance greatly appreciated. Cheers, Mark 2016-12-12 18:12:24.5625 Error HttpServer: Error processing request for /dlna/46e0bdd1abdb8df56faa12ca3ff2e27b/contentdirectory/events *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\Study\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Study\AppData\Roaming\Emby-Server Application Path: C:\Users\Study\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Event with Id uuid:1994096976fc47feb69318b0bd681d93 not found. ServiceStack.HttpError No Stack Trace Available InnerException: MediaBrowser.Common.Extensions.ResourceNotFoundException Event with Id uuid:1994096976fc47feb69318b0bd681d93 not found. at MediaBrowser.Dlna.Eventing.EventManager.GetSubscription(String id, Boolean throwOnMissing) at MediaBrowser.Dlna.Eventing.EventManager.RenewEventSubscription(String subscriptionId, Nullable`1 timeoutSeconds) at MediaBrowser.Api.Dlna.DlnaServerService.ProcessEventRequest(IEventManager eventManager) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2016-12-12 18:12:24.5625 Error ServiceStackHost: [::ffff:192.168.0.26]:8096 Request not found: /dlna/46e0bdd1abdb8df56faa12ca3ff2e27b/contentdirectory/events 2016-12-12 18:12:24.5625 Info HttpServer: HTTP Response 404 to 192.168.0.15. Time: 0ms. http://192.168.0.26:8096/dlna/46e0bdd1abdb8df56faa12ca3ff2e27b/contentdirectory/events server-63617162898.txt
Luke 42288 Posted December 12, 2016 Posted December 12, 2016 Hi @@mrf0ster can you try removing your plugins and seeing if the issue persists with just the core server? You can quickly do that by shutting down and grabbing the dll files from here: C:\Users\Study\AppData\Roaming\Emby-Server\plugins and just moving them somewhere else temporarily. thanks. 1
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 I rebooted but it keeps telling me That And in use by another process be possible? server-63617139238.txt
AvengersFan 10 Posted December 12, 2016 Posted December 12, 2016 Thanks Luke, that worked for me. Cheers Mark
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 (edited) I rebooted but it keeps telling me That And in use by another process be possible? Your creating a loop trying to move something from one place to the same place this is why the file is already in use. Why are you Auto Organizing Library folders? You Organize new stuff into your library not the library itself. 2016-12-12 11:34:52.6462 Info App: Sorting file D:\SerieTV\Film\Film\Serietv\Legends of Tomorrow Season 1\DC's Legends of Tomorrow - 1x01 - Pilot (1).mp4 into series D:\SerieTV\Film\Film\Serietv\Legends of Tomorrow Season 1 Edited December 12, 2016 by Happy2Play
Luke 42288 Posted December 12, 2016 Posted December 12, 2016 Thanks @@Happy2Play. I will update auto organize to not allow that.
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 and how to solve this problem is no option du emby? It recreates existing folders
Heckler 147 Posted December 12, 2016 Posted December 12, 2016 Been away for a few days with the mediaserver shut down since Thurs morning... Came back this afternoon and booted it up... it started it's media library scan and has been stuck at 37.7% for about 3hrs now. I thought perhaps it had crashed, so I cancelled it and restarted the scan... Once again it's stuck at 37.7% for about a further 2hrs now.
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 Been away for a few days with the mediaserver shut down since Thurs morning... Came back this afternoon and booted it up... it started it's media library scan and has been stuck at 37.7% for about 3hrs now. I thought perhaps it had crashed, so I cancelled it and restarted the scan... Once again it's stuck at 37.7% for about a further 2hrs now. Please post your Server log. The percentage is deceiving as my initial scan took 20+ hour and stayed at 52% most of the time.
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 and how to solve this problem is no option du emby? It recreates existing folders You need to reconfigure your Auto Organize settings. But unfortunately any changes it has already attempted or has made you will have to manually undo.
Heckler 147 Posted December 12, 2016 Posted December 12, 2016 (edited) Please post your Server log. The percentage is deceiving as my initial scan took 20+ hour and stayed at 52% most of the time. I think I know what may have caused it... I upgraded my server storage last week, transferred a lot of files around to even out movies across 3 drives... and that meant one of the library folders emby was looking for no longer existed. Rebuilt the library storage and running a rescan which is now at 39.4%... will leave that a couple of hours first and then check if it's progressed further. But I've redistributed 1800+ movies stored in 4 locations into 3 locations now... the majority of which haven't moved... but a good 500+ have... Everything starting with 'D-P' has changed location as has everything starting with 'The' I thought it would have run it's scan already... then remembered I shut emby down during the upgrade/moving files to stop any duplications occurring. Edited December 12, 2016 by Heckler
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 You may want to ensure "Chapter extraction during library scan" is disabled if configured. 1
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 You need to reconfigure your Auto Organize settings. But unfortunately any changes it has already attempted or has made you will have to manually undo. and how should I proceed to reconfigure all your folders? in the sense to delete and redo the various sections such films and TV series?
Happy2Play 9814 Posted December 12, 2016 Posted December 12, 2016 and how should I proceed to reconfigure all your folders? in the sense to delete and redo the various sections such films and TV series? What exactly are you trying to do? Auto Organize is meant to move new content into your library. If you are wanting Emby to restructure your media folder, they can not be Libraries also.
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 What exactly are you trying to do? Auto Organize is meant to move new content into your library. If you are wanting Emby to restructure your media folder, they can not be Libraries also. I made some changes of deleted folders and insert new folders but if it does not end the scanzione I do not take me
Luke 42288 Posted December 12, 2016 Posted December 12, 2016 If you're interested in trying the beta release that would be helpful. All you need to do is install from the website on top of your existing version. thanks.
secagratis 21 Posted December 12, 2016 Author Posted December 12, 2016 I installed the beta also removed from the emby serietv folder, but always the same problem I tried to ancche riniminare the folder does not do more how to make server-63617183509.txt
