keith2045 7 Posted December 11, 2016 Posted December 11, 2016 I have 3 amazon fire tv devices. One of them is fairly new while the other 2 are somewhat older. I just ripped a bluray video and the end size is about 16GB. On one of my devices playback works without any issues but on another device it stops playing every so often (maybe 10 seconds or so). I switched to an external player and playback was flawless, the problem is when I end the video I just get a grey screen when returning back to Emby. In order to successfully relaunch emby i have to force close it. I tried 2 external players (VLC, and Mr something), both had the same issue. I've also tried changing the bit rate settings without success. Both devices are hardwired (gigabit connection) to the server. Any thoughts on how i can get playback to work? I'd be ok with the build in player, or an external one
Jdiesel 1437 Posted December 11, 2016 Posted December 11, 2016 (edited) @@keith2045 Are you running the beta version of the Android TV app? If not I suggest you do as version 1.3 solved a lot of my issues with the app. Edited December 11, 2016 by Jdiesel
keith2045 7 Posted December 11, 2016 Author Posted December 11, 2016 No I'm not. Not really sure how to get the beta. Searching now
Jdiesel 1437 Posted December 11, 2016 Posted December 11, 2016 https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/&do=findComment&comment=238261
keith2045 7 Posted December 11, 2016 Author Posted December 11, 2016 Just tried the beta version, same issues (both, bad playback, and grey screen when closing VLC). I just noticed that the network connection for that device is maxing out at 100mb. Might try using a 1gb connection, but not sure that will fix the issue.
ebr 16337 Posted December 11, 2016 Posted December 11, 2016 Can you please provide both a server and ffmpeg (if it exists) log from that playback? How to Report a Problem
keith2045 7 Posted December 12, 2016 Author Posted December 12, 2016 Attached are the logs. I just noticed that another file worked without any issues and it's larger. I'm going to try recreating the mkv file, i did it a little different. ffmpeg.txt serverlog.txt
Solution Luke 42244 Posted December 12, 2016 Solution Posted December 12, 2016 The reason for the poor playback is due to burning in subtitles, which is often painful. To resolve this, you can either disable subtitles, or consider acquiring text-based subtitles that won't require burn in. Also in a future release our internal video player will be able to handle these PGS subs without burn-in, but for now, it has to use the server for that. 1
