Jdiesel 1435 Posted December 11, 2016 Posted December 11, 2016 Can you test with an unsecure connection to rule that out?
pappaq 8 Posted December 11, 2016 Author Posted December 11, 2016 Can you test with an unsecure connection to rule that out? I will try that tomorrow and report back. Thank you guys.
pappaq 8 Posted December 12, 2016 Author Posted December 12, 2016 I will try that tomorrow and report back. Thank you guys. OK, I tried it and it doesn't make a difference. http or https both get me around 650kbyte/s. Any other ideas?
pappaq 8 Posted December 12, 2016 Author Posted December 12, 2016 That's embarassing...I think I've found the failure. I set rules for emby in my firewall now. Seems to work now. I get downloadspeeds of around 2.5-3.5Mbyte/s.
pappaq 8 Posted December 12, 2016 Author Posted December 12, 2016 (edited) What rule caused this? That was the problem. There was no rule at all. I have set them now, one inbound and one outbound for the emby server application and that had a large impact on the speed. I will test the streaming now for some days and will report back! Edited December 12, 2016 by pappaq
Luke 42241 Posted December 12, 2016 Posted December 12, 2016 Thanks for the info. That's quite interesting. I haven't heard of a firewall rule affecting performance. Usually it just winds up affecting connectivity.
pappaq 8 Posted December 21, 2016 Author Posted December 21, 2016 Hey! After more than one week now, the streaming works great! Even 5 simultaneous 5mbit 1080p streams do work.
