al15 0 Posted December 10, 2016 Posted December 10, 2016 Hello, i am new to emby - so far i only used Kodi as standalon and TMM for metadata management. Today i installed emby and also got the connection to kodi running but now i face some problems with my nfo files and box sets. I have all movies in a single directory and used TMM to organize the box sets. Movies without box set are working fine but movies with this tags are not getting all data from the nfo (basically everything before the tag is imported) - here a sample: <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <!-- created on 2016-11-19 20:56:35 - tinyMediaManager 2.9 --> <movie> <title>Batman Begins</title> <originaltitle>Batman Begins</originaltitle> <set> <name>The Dark Knight Filmreihe</name> <overview>Neuauflage der Comicfigur Batman von Christopher Nolan als Trilogie (2005 - 2012)</overview> </set> <sorttitle></sorttitle> <rating>7.3</rating> <year>2005</year> <top250></top250> <votes>4705</votes> if i remove the <set> tag the nfo is imported successfully... Here my questions: - is there a way to modify the MofieNfoProvider to allow this tags - is there a way to use this tag to create the box information for emby? THANKS lg Al
Luke 42204 Posted December 10, 2016 Posted December 10, 2016 I thought the set tag was just supposed to be a text node?
al15 0 Posted December 10, 2016 Author Posted December 10, 2016 Hi, the new set tags where added in v16 now the format is like this: <set> <name>'name of set'</name> <overview>'plot of set'</overview> </set> Here the info from the release notes: * Added support for set overview (plot) in movie sets in the video libra Any chance to support this in the MovieNfoProvider? THANKS lg AL
Luke 42204 Posted December 10, 2016 Posted December 10, 2016 We'll look at it for a future update, thanks.
al15 0 Posted January 2, 2017 Author Posted January 2, 2017 (edited) Hi Luke, any way that i can track this change somehow ? thanks lg AL UPDATE: put the issue now into the github issue tracker - hope this is the right procedure Edited January 2, 2017 by al15
al15 0 Posted July 30, 2017 Author Posted July 30, 2017 Hi. as the github issue was closed (waiting for update on kodi wiki) can you please build in a skip in case of an unknown tag as otherwise the following infos are not added to the DB. Thanks lg Alois
al15 0 Posted July 30, 2017 Author Posted July 30, 2017 Hi, the tag: <set> <name>The Dark Knight Filmreihe</name> <overview>Neuauflage der Comicfigur Batman von Christopher Nolan als Trilogie (2005 - 2012)</overview> </set> The problem is that emby also not reading any information after this tag.. THANKS lg Alois
Luke 42204 Posted August 2, 2017 Posted August 2, 2017 Hi, the tag: The Dark Knight Filmreihe Neuauflage der Comicfigur Batman von Christopher Nolan als Trilogie (2005 - 2012) The problem is that emby also not reading any information after this tag.. THANKS lg Alois @@al15, this is resolved for the next release, thanks.
al15 0 Posted August 9, 2017 Author Posted August 9, 2017 Hi Luke, thanks i tested the latest beta and it seams the issue with not looking up the other infos is fixed - THANKS Additional the Kodi wiki was now changed to reflect the new set tag format: http://kodi.wiki/view/NFO_files/movies#Movie_sets Can you please also add the support for the new format: <set><name>My movie set</name><overview>This is my awesome movie set.</overview></set> The <overview> tag is optional, and the current format will still be supportedto not break existing scrapers or local NFO files. THANKS again for the great support lg AL
feardamhan 6 Posted January 13, 2018 Posted January 13, 2018 Hi Folks Does emby currently support writing the <set> tag? Been searching but not 100% sure!
feardamhan 6 Posted January 14, 2018 Posted January 14, 2018 Thanks Luke. So putting something in a collection doesnt seem to add the set for me. Is that the way to do it? I'm missing something obvious.
Happy2Play 9802 Posted January 14, 2018 Posted January 14, 2018 Thanks Luke. So putting something in a collection doesnt seem to add the set for me. Is that the way to do it? I'm missing something obvious. I believe Emby only writes the <set> tag with collections on TMDB, when pulling metadata. It doesn't write custom collections (at least it didn't in the test I just did).
Luke 42204 Posted January 14, 2018 Posted January 14, 2018 It comes from data from moviedb, if you have that metadata provider enabled.
feardamhan 6 Posted January 16, 2018 Posted January 16, 2018 I have it enabled as the secondary provider. So its fair to say that whether its pulled in or not is dependent fully on whether moviedb has a collection set up for those movies. I could presumably manually enter the <set> tags in the nfo file and have them honoured but there is no way to do so through metadata manager?
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 Correct, and I think we just haven't added that into the metadata editor. It's possible for the future.
feardamhan 6 Posted January 24, 2018 Posted January 24, 2018 Thanks for the confirmation Luke. Would be nice enhancement, but for the amount I'd need it I'd happily tweak the NFO files directly.
