Guest asrequested Posted December 10, 2016 Posted December 10, 2016 I changed to your settings, eveything worked except the DXVA2copyback acceleration, had to change it back to "Auto". It is now playing with "Direct Playing" and Dolby D, awesome. Will monitor to see how it plays, and see if the volume keeps dropping like some other videos. And you've set your AVR as your WASAPI device?
clarkss12 304 Posted December 10, 2016 Author Posted December 10, 2016 And you've set your AVR as your WASAPI device? Yes.
clarkss12 304 Posted December 10, 2016 Author Posted December 10, 2016 (edited) Been watching "A Christmas Story" for about an hour now and it plays very well with "Direct Playing". Like the other videos, there is an occasional audio "sag", not really a drop out of audio, just volume drops a little. Not sure it is due to this server software or some other causes like network or devices that are storing my media. Anyway I am attaching a log, if any one cares to take a look. The last volume "sag" was around the 18:01 mark, give or take a few seconds. I would classify watching this video in its present condition of comfort level of 98 of 100, not perfect but almost. Watched "Home Alone" last night (only half of it), but the comfort level would be about 92 of 100 because of the audio volume drops. Edit: 192.168.10.103 is my Tronsmart Ara X5 running both server and ET that I am playing the movie on. 192.168.10.102 is my Windows 7 desktop PC that I am monitoring the Emby dashboard 192.168.10.74 is my Synology NAS that I am playing this movie from. 192.168.10.111 is my WD NAS, but not playing any media from it, but it shows up in the log during that time frame. A Christmas Story server log.txt Edited December 10, 2016 by clarkss12
Jdiesel 1435 Posted December 10, 2016 Posted December 10, 2016 Can you reproduce the audio sags on another player (VLC or MPC)? If it is direct playing the issues is definently on the client end of things.
clarkss12 304 Posted December 10, 2016 Author Posted December 10, 2016 Can you reproduce the audio sags on another player (VLC or MPC)? If it is direct playing the issues is definently on the client end of things. I will test it later on VLC.
Luke 42243 Posted December 10, 2016 Posted December 10, 2016 Even that is an apples to oranges comparison because correct me if i'm wrong but vlc does not have wasapi output.
Jdiesel 1435 Posted December 10, 2016 Posted December 10, 2016 True, MPC-HC with LAV would be a better comparison.
clarkss12 304 Posted December 10, 2016 Author Posted December 10, 2016 (edited) True, MPC-HC with LAV would be a better comparison. OK Testing now with MPC. Will test for half an hour and report. Edited December 10, 2016 by clarkss12
Guest asrequested Posted December 10, 2016 Posted December 10, 2016 But if it's bitstreaming there shouldn't be any software involvement. It's all down to the AVR.
Guest asrequested Posted December 10, 2016 Posted December 10, 2016 @@clarkss12 what model is your AVR?
clarkss12 304 Posted December 11, 2016 Author Posted December 11, 2016 @@clarkss12 what model is your AVR? Denon AVR-S700W Had a couple of volume sags while using the MPC app in half hour of watching.
Jdiesel 1435 Posted December 11, 2016 Posted December 11, 2016 (edited) Could be the media file itself or maybe a dynamic range setting on your AVR. On Denon AVRs it usually called Dynamic Volume. My bet is the file itself. Edited December 11, 2016 by Jdiesel 1
clarkss12 304 Posted December 11, 2016 Author Posted December 11, 2016 Could be the media file itself or maybe a dynamic range setting on your AVR. On Denon AVRs it usually called Dynamic Volume. My bet is the file itself. Yes it could be the file. Have not tested it on other devices or different storage devices.
Guest asrequested Posted December 11, 2016 Posted December 11, 2016 Yes it could be the file. Have not tested it on other devices or different storage devices. Share a sample of the file
clarkss12 304 Posted December 11, 2016 Author Posted December 11, 2016 Share a sample of the file Not sure a sample will help.
Solution Guest asrequested Posted December 11, 2016 Solution Posted December 11, 2016 Check these settings in your AVR. http://manuals.denon.com/AVRS700W/NA/EN/GFNFSYvdfworfs.php 2
clarkss12 304 Posted December 11, 2016 Author Posted December 11, 2016 Check these settings in your AVR. http://manuals.denon.com/AVRS700W/NA/EN/GFNFSYvdfworfs.php Amazing, made a couple of adjustments per your suggestion, played "Home Alone" again (had bad volume drops yesterday) and NO volume drops at all for about 30 minutes of playing. 1
Guest asrequested Posted December 11, 2016 Posted December 11, 2016 Amazing, made a couple of adjustments per your suggestion, played "Home Alone" again (had bad volume drops yesterday) and NO volume drops at all for about 30 minutes of playing. I'm glad we could resolve your issue
Luke 42243 Posted December 11, 2016 Posted December 11, 2016 Enjoy And thanks Doofus for helping him.
clarkss12 304 Posted December 11, 2016 Author Posted December 11, 2016 I am grateful for all your your help..
Luke 42243 Posted April 30, 2017 Posted April 30, 2017 @@clarkss12 @@Marc_G The next release of Emby Theater will feature improved performance, hardware acceleration, and better multi-monitor support. If you'd like to try it out ahead of time you can do so here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-1 Enjoy.
