Gummix 4 Posted December 8, 2016 Author Posted December 8, 2016 (edited) I try Filebot atm. It adds the Year and search the name in theMovieDb.org Edited December 8, 2016 by Gummix
Happy2Play 9814 Posted December 8, 2016 Posted December 8, 2016 Having the year in the name always give more reliable media identification.
Gummix 4 Posted December 8, 2016 Author Posted December 8, 2016 Yes^^ it where a nice Plugin for Emby, a renamer ike this xD
Gummix 4 Posted December 9, 2016 Author Posted December 9, 2016 Or i renamed every Movie. He know find it. Next question: Is there a was to delete/exclude folder from the Database? I only find a way to delete File and Database entry. Its cause OMV put in every partition Folder like "lost&found" "System Volume Information" and Emby set there is the Movie/Series List. I also cant delte them from the HDD cause OMV create them anyway new^^ Thanks and Greetings
ebr 16354 Posted December 9, 2016 Posted December 9, 2016 Or i renamed every Movie. He know find it. Next question: Is there a was to delete/exclude folder from the Database? I only find a way to delete File and Database entry. Its cause OMV put in every partition Folder like "lost&found" "System Volume Information" and Emby set there is the Movie/Series List. I also cant delte them from the HDD cause OMV create them anyway new^^ Thanks and Greetings It is typically best not to point a media library at a root of a drive for this reason. If the software is doing this beyond the root, then you can put a ".ignore" file in the folder for Emby to ignore it completely.
Gummix 4 Posted December 9, 2016 Author Posted December 9, 2016 Ah ok thanks, i will test it. Greetings
Gummix 4 Posted December 9, 2016 Author Posted December 9, 2016 So, i added a Emby.ignore File into the Lost & Found folder but Emby still add them to the Databank
Luke 42289 Posted December 9, 2016 Posted December 9, 2016 Is this a standard OMV folder? we could just ignore it by default if it is.
Gummix 4 Posted December 9, 2016 Author Posted December 9, 2016 I have 5 HDDs in the Server and 1 Main SSD (where the System runs) All HDDs have the "lost+found" (empty) folder and just one of the HDDs has the folder "System Volume Information" with 3 files in it "IndexerVolumeGuid", "tracking.log", "WPSettings.dat" So i think that at least the lost+found is a standard folder.
