Muad 0 Posted December 8, 2016 Posted December 8, 2016 i have a intel core i7 930 cpu and 12 gig with ram, I am trying too transcode mulitple streames too diffrent users.But it seems that my system overloads and crashes when i do that, i have set the cpu count too 4 too over come the system crashes. but still the users complains that what they are watching is laggy,Is my hardware too small too handle 2 - 4 transcoding at the same time ? transcode_log.txt server_log.txt
jdemby 0 Posted December 27, 2016 Posted December 27, 2016 (edited) It should be able to do it. check your load average (via top or uptime) You'll see load average: 0.78, 0.78, 0.78 That means number of process running / number that want to run for 1, 5 and 15 minutes. If your under high load (anything over maybe a 4 or 5) you may be at your limit. There are a few things you might try. Run the server under a Jail as opposed to a VM Set compiler options in your make.conf and rebuild the port such as: CPUTYPE?=corei7 I think thats right you'll have to check, I have AMD hardware, also be careful with that and don't set -O flags and the native flag is supposed to be bad to set also. thats about all you can do tho and any gains will be pretty small. Edit: also there is htop or slmon that gives you a nice cpu bar graph. Edit2: ZFS compression modes can eat up CPU also. lz4 (the default) should be ok but its not needed on media because its already compressed. Edited December 27, 2016 by jdemby
Muad 0 Posted January 6, 2017 Author Posted January 6, 2017 load averages: 6.93, 3.40, 1.61that is from one transcoding thread, having more than 2 threads running on the server at once is not working. I see the ffmpeg has -0:s flag set... cant find a way too tweak the flags ffmpeg is using? maybe time too upgrade too a xenox server if i need more threads too transcode videos, but fracking frack the xenox cpu is expensive hw.model: Intel® Core i7 CPU 930 @ 2.80GHzhw.machine: amd64hw.ncpu: 8
Luke 42238 Posted January 6, 2017 Posted January 6, 2017 I would suggest going back to automatic thread count because ffmpeg is usually pretty good at managing it on it's own.
makarai 109 Posted January 10, 2017 Posted January 10, 2017 I am not sure if it helps but if you transcode 1080p movies as rule of thumb is about a passmark score of 2000. So technically you should be able to transcode ~2 movies at the same time. https://cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-930+%40+2.80GHz&id=835
