fredg89 8 Posted December 8, 2016 Posted December 8, 2016 All, I'm in need of a program that I can go in and rename audio as some of my files have audio as "unkown" and would like to remove some subtitles that I wouldn't use. Is there a program that can do this without changing the format or reencoding the file?
fredg89 8 Posted December 8, 2016 Author Posted December 8, 2016 You can use mkvtoolnix I see how I could use that to take out audio or subtitles but I also need to be able to change the two where it says English instead of unknown so I can know what audio and subtitles my media has.
Waldonnis 148 Posted December 8, 2016 Posted December 8, 2016 I see how I could use that to take out audio or subtitles but I also need to be able to change the two where it says English instead of unknown so I can know what audio and subtitles my media has.It can do that too. Check the header editor features (or tab, if you are using the GUI).
fredg89 8 Posted December 8, 2016 Author Posted December 8, 2016 It can do that too. Check the header editor features (or tab, if you are using the GUI). AHHH!!!!! Awesome! Thanks!!! I Was using the wrong gui lol. I went to the extract gui.
