Jdiesel 1435 Posted December 7, 2016 Posted December 7, 2016 Like the title says, after completing a video it is marked as watched but it isn't removed from the suggestions or latest screens. Shows that are in progress are not disappearing after completion. I tried toggling the watched checkmark but it had no effect. Maybe I am mistaken but I though that after a video was watched it was removed from the latest view. I am on the stable build of Emby server.
Luke 42186 Posted December 7, 2016 Posted December 7, 2016 Hi @@Jdiesel, can you provide the Emby server log from one of these situations? thanks !
MEB 27 Posted December 7, 2016 Posted December 7, 2016 I've seen this happen for a long time, I just keep toggling the check until it disappears, figured it is just a hiccup and a delay with the suggested being updated. Most of the time its the episodes I watch with the android client that get "stuck".
Jdiesel 1435 Posted December 7, 2016 Author Posted December 7, 2016 I can confirm that it has only started happening since I began using the Android TV app recently.
ebr 16307 Posted December 7, 2016 Posted December 7, 2016 I think there is an issue with the current release server responding very slowly to progress reports which could cause the app to send some after playback had stopped. The next server should fix this but, also, the current beta of the app ensures that only one progress report is sent at a time which should also stop it from happening. So, I'd like to know if you can still reproduce this with the new beta of the app. Thx. 1
Jdiesel 1435 Posted December 7, 2016 Author Posted December 7, 2016 Upgrading to the beta server seemed to have cleaned everything up to how it should be right away. I will do some more testing and report back after I've run it through real world usage.
