Erik 124 Posted December 7, 2016 Posted December 7, 2016 Hi, Can't get down to the last channel/line of the guide. You can scroll and hold it visible but it always jumps back down below the bottom links bar. Thanks.
Luke 42243 Posted December 7, 2016 Posted December 7, 2016 @@Erik @@denz Are either of you on the iOS beta? If not and you would like to join the beta then please send me your itunes email address. I cannot reproduce this issue. How many channels do you guys have?
Erik 124 Posted December 7, 2016 Author Posted December 7, 2016 @@Luke I'm not currently part of the beta, but ill PM you my email to participate in it. I have 25 channels and running 1.3.0.
Erik 124 Posted December 7, 2016 Author Posted December 7, 2016 @@Luke Installed Emby IOS 1.3.1 (2) and with server 3.0.85 the problem still exists. I swipe up till get to the end of the Guide then when it corrects the blank space, it corrects most of the bottom line below the menu bar. Screenshot below is the result after it corrects down from a swipe from iPhone 5 (also tested a 5c)
Erik 124 Posted December 7, 2016 Author Posted December 7, 2016 Yes, that's correct. I can swipe/slide to see all the channels and blank space, but then after it slides down to remove the blank space it goes to far.
Solution Luke 42243 Posted December 7, 2016 Solution Posted December 7, 2016 It's resolved for the next beta/release. thanks. 1
denz 501 Posted December 8, 2016 Posted December 8, 2016 Do I still need to join the beta or should I just wait for the update ?. I am not too fussed as that channel I rarely watch but I am glad it is fixed.
Luke 42243 Posted December 8, 2016 Posted December 8, 2016 Well your feedback on the beta would be valuable
denz 501 Posted December 8, 2016 Posted December 8, 2016 Ok I will pm the user name as I like that app and use it frequently just pain that I can't purchase a new one as all the funds are going into the new house that got receintly built. My opinion is better to buy an existing home than to build. It still works perfectly and I think apple is probable not happy with me that I still use it and it hasn't broken down.
Erik 124 Posted December 8, 2016 Author Posted December 8, 2016 Fixed in 1.3.1 (4) Note: you can access the last guide line correctly, but just checking to see if the blank gap it leaves is intentional or if it needs a tweek to move down to the top of the menu bar. Also...i noticed when browsing movies and swiping down the lower menu bar is removed until you swipe back up. Should the guide perform the same way or is that intentionally different.
Luke 42243 Posted December 8, 2016 Posted December 8, 2016 It's fine. The space will be needed if the now playing bar is showing. Yes it would be nice for the guide scroll to hide and show the header and tabs but it's a little trickier so it's not enabled right now.
Erik 124 Posted December 8, 2016 Author Posted December 8, 2016 Ah, good point. Consider it all fixed then. Thanks!
