eraser8 55 Posted December 6, 2016 Posted December 6, 2016 HI All, I did research through forum topics to find same as my situation but I cannot find an exact match of mine. So Sorry if this was already discuss. The problem I currently have is when I start playing a movie through the web interface, the movie can take about 2 or 3 minutes to start. the stranger thing is if I stop it after it start reading, I restart it and it restart instantly... I wonder if someone already saw this kind of problem and have a good idea of what it is? Thanks
strugglez 8 Posted December 6, 2016 Posted December 6, 2016 Could this just be due to transcoding and either having too higher of a setting for what your CPU can handle? Just my thoughts, I'll leave it to the techies though. PS - Just on what you said ebr, when emby transcodes, does the subtitles get embedded/burnt into the transcode or is it just an overlay?
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Do you have subtitles turned on? Yes, in fact I did noticed that there is many subtitle logs during the waiting time. Also, I must also say that It could be related to the fact that this happen most of the time when I play new file that I just put in my Emby library. When Emby found it, theses file are added to the directory: movie.nfo landscape.jpg poster.jpg When I start the movie, it take about 3-4 minutes to start but during this time, there is 2 new files added: fanart.jpg logo.jpg Could it be related to the generation of these file? I found some error log related to the logo.jpg 2016-12-06 15:50:56.1786 Error ProviderManager: IOException saving to \\Eraser-nas\USB_HDD_1\Films\Sully (2016)\fanart.jpg. Le processus ne peut pas accéder au fichier '\\Eraser-nas\USB_HDD_1\Films\Sully (2016)\fanart.jpg', car il est en cours d'utilisation par un autre processus.. Will retry saving to C:\Users\eraser\AppData\Roaming\Emby-Server\metadata\library\41\41288265dbfccae0f6de254e076df070\backdrop.jpg 2016-12-06 15:50:56.9686 Error ImageProcessor: Error cropping image \\Eraser-nas\USB_HDD_1\Films\Sully (2016)\logo.png *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\eraser\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\eraser\AppData\Roaming\Emby-Server Application Path: C:\Users\eraser\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe ImproperImageHeader `\\Eraser-nas\USB_HDD_1\Films\Sully (2016)\logo.png' @ error/png.c/ReadPNGImage/3921 ImageMagickSharp.WandException à ImageMagickSharp.WandCore`1.CheckErrorBool(Int32 status) à ImageMagickSharp.MagickWand.OpenImage(String path) à ImageMagickSharp.MagickWand..ctor(String path) à Emby.Drawing.ImageMagick.ImageMagickEncoder.CropWhiteSpace(String inputPath, String outputPath) à Emby.Drawing.ImageProcessor.<GetWhitespaceCroppedImage>d__35.MoveNext() 2016-12-06 15:50:57.0786 Error ImageProcessor: Error encoding image *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\eraser\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\eraser\AppData\Roaming\Emby-Server Application Path: C:\Users\eraser\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe ImproperImageHeader `\\Eraser-nas\USB_HDD_1\Films\Sully (2016)\logo.png' @ error/png.c/ReadPNGImage/3921 ImageMagickSharp.WandException à ImageMagickSharp.WandCore`1.CheckErrorBool(Int32 status) à ImageMagickSharp.MagickWand.OpenImage(String path) à ImageMagickSharp.MagickWand..ctor(String path) à Emby.Drawing.ImageMagick.ImageMagickEncoder.EncodeImage(String inputPath, String outputPath, Boolean autoOrient, Int32 width, Int32 height, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) à Emby.Drawing.ImageProcessor.<ProcessImage>d__27.MoveNext() Great thanks!
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Could this just be due to transcoding and either having too higher of a setting for what your CPU can handle? Just my thoughts, I'll leave it to the techies though. PS - Just on what you said ebr, when emby transcodes, does the subtitles get embedded/burnt into the transcode or is it just an overlay? Hi Strugglez, Thank you for the idea but I have enough power for that. For proof, when I start it on the second time, it works great instantly!
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Also, I just did notice another point. More heavy is the file, and more longer it take to start the movie... When I try it on a tv episode, (about 500 meg) it take about 15-20 seconds. I'm being downloading a new movie, I will retry it with this new movie but I will try to do a full refresh of the metadata before starting the movie... keep you inform.
Luke 42186 Posted December 7, 2016 Posted December 7, 2016 Please attach the complete emby server log. Thanks !
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Please attach the complete emby server log. Thanks ! Hi Luke, I just did a new test with a new movie and both JPG file seems to not be the cause. Maybe the SUB? I attached all generated logs for this test. It start around 22:41:00 and I've started the movie "Colonia" Thanks ffmpeg-remux-79b25374-276e-4a1e-a661-70c7229ed334.txt ffmpeg-sub-extract-3c1ee2c7-4381-4b97-a372-970179be9573.txt ffmpeg-sub-extract-56fa2aa8-b3dd-4e72-8fb5-4f57654590e5.txt server-63616637090.txt
Luke 42186 Posted December 7, 2016 Posted December 7, 2016 Yes, the subtitle extraction. The reason it starts up immediately the next time is because we save the extracted result for future use. the extraction process should be a little quicker with the next release of emby server. thanks !
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Yes, the subtitle extraction. The reason it starts up immediately the next time is because we save the extracted result for future use. the extraction process should be a little quicker with the next release of emby server. thanks ! Hi Luke Thank you for the response. Is there a way to disable this feature? Thanks
ebr 16307 Posted December 7, 2016 Posted December 7, 2016 Thank you for the response. Is there a way to disable this feature? Don't request subtitle display when playing the item. Or, if you need them, acquire text-based external ones using our facility to do that.
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Don't request subtitle display when playing the item. Or, if you need them, acquire text-based external ones using our facility to do that. Hi ebr, FYI, I didn't request any subtitle display. I just pushed the play button and wait. But it's ok, it's not a big deal, just wanted to know why this happen. I guess if this happen to me, this should happen to everybody? Thanks for your help guys, much appreciated.
ebr 16307 Posted December 7, 2016 Posted December 7, 2016 FYI, I didn't request any subtitle display. I just pushed the play button and wait. But it's ok, it's not a big deal, just wanted to know why this happen. I guess if this happen to me, this should happen to everybody? Then your settings on the server in conjunction with the actual media caused them to be chosen. Investigate the playback settings under your user icon in the web app.
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 (edited) Hi ebr, I just check under the Users/(my user)/ and also in Playback/ and I didn't find any related to subtitle. I'm currently download another movie to retry it. Keep you inform. Edited December 7, 2016 by eraser8
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Oh! I just did the test after changind couple of setting and now it works great on the first start No more delay. Will try to figure out which setting it is and keep you inform. Thanks
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 User Icon->Playback Hum.... ok this is not in the server config page? Anyway, I will figure out which setting I changed on the server page and come back to you after. Great thanks
Happy2Play 9801 Posted December 7, 2016 Posted December 7, 2016 (edited) Are you looking in user preferences/not the dashboard? Edited December 7, 2016 by Happy2Play
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Hi, Yes, I did find the playback setting in the web interface. But I didn't change anything in this section, just in the server setting page. I'm being testing for which parameter on the server setting affect the first play. Be back soon.
eraser8 55 Posted December 7, 2016 Author Posted December 7, 2016 Ok.... now, I'm owned..... I'm trying to get the same behaviour than I had and I'm not able to get the subtitle extraction with the lag at the first start... Anyway, Thank you all for your help. All works great now.
