Marc_G 95 Posted December 4, 2016 Posted December 4, 2016 Hi folks, I'm switching from WMC to full on Emby, and have discontinued WMC recordings of OTA TV and set up new series in Emby. I'm using the current stable server release on a Win 7 platform. Last night, Emby was supposed to record Saturday Night Live from 11:30 pm to 1 am, plus 3 minutes of padding on either side. So, I was expecting a 96 minute recording. However, it was only 66 minutes long... it stopped at 12:33 am apparently. Or at least that what appears to have happened based on the MKV file that was produced. The real story is apparently more complicated. I'll attach the server log... it's a whole day's worth and I was doing stuff on the HTPC when the recording kicked off so there's a lot in there, but the relevant entry that tells me Emby knew to record the whole show is: 2016-12-03 23:26:00.8536 Info App: Beginning recording. Will record for 98.9857566133333 minutes. OK, I expected 96 minutes but that's close enough... :-) The log restarted at midnight automatically. So, in the second log I searched through (OMG! So much stuff from live TV channels I never watch in there!) to find the ending of the SNL recording. Didn't see anything around 00:33:00 or so when I thought the recording stopped early. But down at around the ~1:03 am time when I would have expected the recording to stop, I got this: 2016-12-04 01:05:00.0563 Info App: Killing ffmpeg recording process for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.4583 Debug LibraryMonitor: Changed detected of type Changed to E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.4583 Debug LibraryMonitor: Ignoring change to E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.6024 Error App: Error in QueueStream *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.BeginWrite(Byte[] buffer, Int32 offset, Int32 count, AsyncCallback cback, Object state) at System.IO.Stream.<>c.<BeginEndWriteAsync>b__53_0(Stream stream, ReadWriteParameters args, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrim[TInstance,TArgs](TInstance thisRef, TArgs args, Func`5 beginMethod, Func`3 endMethod) at System.IO.Stream.BeginEndWriteAsync(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.WriteAsync(Byte[] buffer, Int32 offset, Int32 count, CancellationToken cancellationToken) at MediaBrowser.Server.Implementations.LiveTv.TunerHosts.QueueStream.<StartInternal>d__16.MoveNext() InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) 2016-12-04 01:05:00.6964 Info App: FFMpeg recording exited with code 0 for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.6964 Info App: Recording completed to file E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.6964 Info App: Recording completed: E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:00.7124 Error ServiceStackHost: Error occured while Processing Request: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at ServiceStack.Formats.HtmlFormat.SerializeToStream(IRequest req, Object response, IResponse res) at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse(IResponse httpRes, IRequest httpReq, String contentType, String operationName, String errorMessage, Exception ex, Int32 statusCode) at ServiceStack.ServiceStackHost.HandleUncaughtException(IRequest httpReq, IResponse httpRes, String operationName, Exception ex) at ServiceStack.HostContext.RaiseAndHandleUncaughtException(IRequest httpReq, IResponse httpRes, String operationName, Exception ex) at ServiceStack.HttpResponseExtensionsInternal.HandleResponseWriteException(Exception originalEx, IRequest request, IResponse response, String defaultContentType) at ServiceStack.HttpResponseExtensionsInternal.<WriteToResponse>d__6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at ServiceStack.Host.RestHandler.<ProcessRequestAsync>d__13.MoveNext() InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) 2016-12-04 01:05:00.7124 Info HttpServer: HTTP Response 500 to 127.0.0.1. Time: 5939660ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3a8ea24ae312434f97d9d374755c4239/stream.ts2016-12-04 01:05:00.7744 Info App: Live stream c8e3fa5a2b3f418fa6d25c04c80cfb96_native_6a400a18a1fb928db2a3f69f1477afa1 consumer count is now 02016-12-04 01:05:00.7864 Info App: Closing live stream c8e3fa5a2b3f418fa6d25c04c80cfb96_native_6a400a18a1fb928db2a3f69f1477afa12016-12-04 01:05:00.7864 Info App: Closing HDHR live stream2016-12-04 01:05:00.8074 Info App: Live stream c8e3fa5a2b3f418fa6d25c04c80cfb96_native_6a400a18a1fb928db2a3f69f1477afa1 closed successfully2016-12-04 01:05:13.1301 Debug PortMapper: Calling Nat.Handle on uuid:4d696e69-444c-164e-9d44-00000000cc08::urn:schemas-upnp-org:service:WANIPConnection:12016-12-04 01:05:19.6464 Info HttpServer: HTTP GET http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml. UserAgent:2016-12-04 01:05:19.6464 Info Dlna: No matching device profile found. The default will need to be used. Host: 192.168.1.4:8096 Accept: */*2016-12-04 01:05:19.6644 Info HttpServer: HTTP Response 200 to 192.168.1.21. Time: 19ms. http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml2016-12-04 01:05:45.8149 Debug LibraryMonitor: New file refresher created for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:05:52.4723 Info HttpServer: HTTP GET http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml. UserAgent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.502016-12-04 01:05:52.4723 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Close Pragma: no-cache Accept: text/xml, application/xml Host: 192.168.1.4:8096 User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.502016-12-04 01:05:52.4723 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 2ms. http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml2016-12-04 01:06:19.6639 Info HttpServer: HTTP GET http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml. UserAgent:2016-12-04 01:06:19.6639 Info Dlna: No matching device profile found. The default will need to be used. Host: 192.168.1.4:8096 Accept: */*2016-12-04 01:06:19.6639 Info HttpServer: HTTP Response 200 to 192.168.1.21. Time: 1ms. http://192.168.1.4:8096/dlna/1134a6d6915d98d826e9ced2f44798d3/description.xml2016-12-04 01:06:45.8244 Debug LibraryMonitor: Timer stopped.2016-12-04 01:06:45.8904 Info LibraryMonitor: E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv reports change.2016-12-04 01:06:45.8904 Info LibraryMonitor: Season 42 (E:\LiveTVSeries\Saturday Night Live\Season 42) will be refreshed.2016-12-04 01:06:46.0324 Debug App: Running FFProbeProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:46.0324 Debug MediaEncoder: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffprobe.exe -i file:"E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format2016-12-04 01:06:46.9394 Debug App: Running EpisodeNfoProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:46.9454 Debug App: EpisodeNfoProvider returned no metadata for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:46.9454 Debug App: Running EpisodeXmlProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:46.9454 Debug App: EpisodeXmlProvider returned no metadata for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:46.9454 Debug App: Running TvdbEpisodeProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:47.0814 Debug App: Running TvdbEpisodeImageProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:47.0865 Debug App: Running MovieDbEpisodeImageProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:47.0865 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/tv/1667/season/42/episode/8?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,external_ids,credits,videos&language=en&include_image_language=en,null2016-12-04 01:06:47.3985 Debug JsonSerializer: Deserializing file C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\cache\tmdb-tv\1667\season-42-episode-8-en.json2016-12-04 01:06:47.3985 Debug App: Running OmdbImageProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:47.3985 Debug App: Running VideoImageProvider for E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv2016-12-04 01:06:47.3985 Debug MediaEncoder: C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe -ss 00:06:32.927 -i file:"E:\LiveTVSeries\Saturday Night Live\Season 42\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\cache\temp\9b4f1a76-c6a5-4b02-be38-8089139ec651.jpg"2016-12-04 01:06:48.5466 Debug ProviderManager: Saving image to C:\Users\HomeTheater\AppData\Roaming\MediaBrowser-Server\metadata\library\cc\cc18f9d14712925676f53bc3d31905e0\Saturday Night Live S42E08 Emma Stone; Shawn Mendes.jpg Basically it looks to my uneducated eye that it recorded the whole thing but then something happened and it resulted in a 66 minute file. Both server logs plus the transcode log are in the attached zip. Thanks in advance for any help! Marc SNL Recording Error files.zip
Luke 42242 Posted December 4, 2016 Posted December 4, 2016 Please see if this happens with the next release of Emby Server. Thanks.
Marc_G 95 Posted December 4, 2016 Author Posted December 4, 2016 Thanks. Will do. What would you recommend I do in the meantime? I've unchecked the "convert to streaming-friendly format" for now, since it "seems" like the problem happened during conversion after a full length recording. I don't really care much about the format in the short term; did the MKV thing just for consistency since all my other content is MKV. Anything else I should do to set my mind at ease... the ticklish part is that it was my wife's show that got botched... Yikes! Gotta make sure it doesn't happen again....
Marc_G 95 Posted December 12, 2016 Author Posted December 12, 2016 Just to document this: I turned off the conversion to mkv and SNL recorded fine on Saturday. The recording in .ts format was the correct length.
