FrostByte 5464 Posted December 5, 2016 Posted December 5, 2016 I thought we were hosting the stable app. You are, but cmcg never moved the latest beta to stable before leaving. The latest beta is more stable and the final version
SamES 1088 Posted December 5, 2016 Posted December 5, 2016 I thought we were hosting the stable app. You are, but there have been a lot of changes since then that cmcg is hosting as the beta version. Version i seems to be the latest beta (although github repo doesn't seem to be up-to-date). I think the issue is only being able to host one version of the app at the time. If we are happy to make version i the stable release, then you could host it. If the changes for @@anderbytes is OK, we can make it version j and host it 1
anderbytes 141 Posted December 5, 2016 Author Posted December 5, 2016 Hey guys! The beta of Samsung App that I received via PM works allright! 2
Luke 42289 Posted December 5, 2016 Posted December 5, 2016 Have you reported the dlna issue to your TV manufacturer?
SamES 1088 Posted December 5, 2016 Posted December 5, 2016 Dlna still broken, though I'm curious, if you copy this file to a USB and try and play it, does it play correctly on the TV or does it have the same problem as via DLNA?
anderbytes 141 Posted December 5, 2016 Author Posted December 5, 2016 I'm curious, if you copy this file to a USB and try and play it, does it play correctly on the TV or does it have the same problem as via DLNA? It is a good test. Unfortunately there are people sleeping where the Samsung TV lies, so I'll be only able to test this again tomorrow after work.
anderbytes 141 Posted December 5, 2016 Author Posted December 5, 2016 (edited) Have you reported the dlna issue to your TV manufacturer? I'm sorry to say that, as I live in Brazil (or any other South America country), LG and Samsung don't give a damn about what we... monkeys... think or say. In the past I've already tried reporting stuff or getting some kind of answer of any kind... sometimes I get a standard "We received your message! Thank you!" and nothing happens, but most of the times... silence. I'm pretty sure that if one of you US would report the issue... we would have 10x more chance of seeing it corrected in the future. Edited December 5, 2016 by anderbytes
SamES 1088 Posted December 6, 2016 Posted December 6, 2016 Hey guys! The beta of Samsung App that I received via PM works allright! That's great. Well done getting it loaded. I think now we need to create a new stable release. 1
