Doonga 17 Posted December 2, 2016 Posted December 2, 2016 I have machines running theater both on the same version, 2.5.30. On one of them the live TV guide settings button (near the date picker) is missing. Not sure what happened there.
blade005 185 Posted December 3, 2016 Posted December 3, 2016 (edited) I have machines running theater both on the same version, 2.5.30. On one of them the live TV guide settings button (near the date picker) is missing. Not sure what happened there. What is your screen resolution on each machine? I have two systems and only the PC that has a display resolution of 1920 x 1080 shows the guide setting button. System that is set to 1280 x 720 resolution does not show the guide setting button. Edited December 3, 2016 by blade005
Luke 42243 Posted December 3, 2016 Posted December 3, 2016 We will be revisiting this design soon, thanks guys.
Doonga 17 Posted December 3, 2016 Author Posted December 3, 2016 They're both 1920x1080. At least they should be... I'll double check. It's not a huge deal, just something I noticed. Thanks Luke!
