huge 0 Posted December 2, 2016 Posted December 2, 2016 (edited) First off - I do not have much linux experience, so apologies in advance for my ignorance Second - I posted about this in the Debian thread and received a lot of help from @@hurricanehrndz and @@Gronkdalonka. @@hurricanehrndz suggested that I should post a new topic/thread, so here I am... I'm trying to install Emby Server on a Pogoplug V4 running Debian 7.11 (Wheezy). The Pogoplug is described on this page as: Architecture: ARMv5te Processor: Marvell Kirkwood 800MHz RAM: 128MB NAND: 128MB I have a 3TB external hard drive attached via USB 3.0 to the Pogoplug, and I'm currently using it as a Samba media server for my Windows home network (mostly to serve media to a Windows 7 HTPC running WMC & MediaBrowser2, MPC-BE, LAV Filters). Before I even ask about installation issues, can anyone warn me off if my Pogoplug is just too wimpy to effectively run Emby? I see evidence of someone running Emby on a Goflex, which is similar architecture but a faster processor. OK, so in trying to install Emby, I'm running into a bunch of "unmet dependencies" which seem to be connected to me not having access to the Mono package. With various repositories I'm always running into something more or less like the following: root@PogoV4Debian:~# echo 'deb http://download.opensuse.org/repositories/home:/emby/Debian_7.0/ /' > /etc/apt/sources.list.d/emby-server.list root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# ls /etc/apt/sources.list.d/ . .. emby-server.list root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# cat /etc/apt/sources.list.d/* deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ / root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# apt-get update Hit http://download.webmin.com sarge Release.gpg Hit http://ftp.us.debian.org wheezy Release.gpg Hit http://security.debian.org wheezy/updates Release.gpg Hit http://ftp.us.debian.org wheezy Release Hit http://security.debian.org wheezy/updates Release Hit http://download.webmin.com sarge Release Hit http://download.opensuse.org Release.gpg Hit http://download.opensuse.org Release Hit http://ftp.us.debian.org wheezy/main armel Packages Hit http://ftp.us.debian.org wheezy/main Translation-en Hit http://security.debian.org wheezy/updates/main armel Packages Hit http://security.debian.org wheezy/updates/contrib armel Packages Hit http://security.debian.org wheezy/updates/non-free armel Packages Hit http://security.debian.org wheezy/updates/contrib Translation-en Hit http://security.debian.org wheezy/updates/main Translation-en Hit http://download.webmin.com sarge/contrib armel Packages Hit http://security.debian.org wheezy/updates/non-free Translation-en Hit http://download.opensuse.org Packages Ign http://download.webmin.com sarge/contrib Translation-en Ign http://download.opensuse.org Translation-en Reading package lists... Done root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# root@PogoV4Debian:~# apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: mono-runtime (>= 3.0~) but it is not going to be installed Depends: libc6 (>= 2.19) but 2.13-38+deb7u11 is to be installed or libc6.1 (>= 2.19) but it is not installable or libc0.1 (>= 2.19) but it is not installable Depends: libmono-corlib4.5-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-transactions4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-xml4.0-cil (>= 3.12.0) but it is not going to be installed Depends: libmono-system4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. root@PogoV4Debian:~# (I've also tried substituting the xUbuntu 14.04 repo) Does anyone have suggestions on how to get mono & emby running? thanks for any assistance you can provide (and for the help I've already received in the Debian thread) -huge Edited December 2, 2016 by huge
Luke 42245 Posted December 3, 2016 Posted December 3, 2016 Hi @@huge. Currently we're not yet sure if the mono runtime supports your CPU architecture. Do you happen to know if you've ever had mono installed before? Thanks !
huge 0 Posted December 4, 2016 Author Posted December 4, 2016 Hi @@huge. Currently we're not yet sure if the mono runtime supports your CPU architecture. Do you happen to know if you've ever had mono installed before? Thanks ! I definitely have not had mono installed - just got the unit running a couple of months ago and the only thing I've done is install Samba & Webmin. If it's something that will likely be added down the line, I'm fine with just waiting - given my low level of linux expertise I'm probably not the best person to explore new territory (unless there's something relatively simple you can suggest to test it). Plus I'm skeptical whether my cheap & slow little box will run Emby effectively even if I can manage to install it. Thanks for your reply! -huge
huge 0 Posted October 13, 2017 Author Posted October 13, 2017 I finally got back to this attempt, tried to follow a page with instructions for installing mono: https://dominicm.com/compile-install-mono-3-6-ubuntu-linux/ But it failed with the following lines after something like an hour running the "make" command: CC libmonoruntimesgen_static_la-string-icalls.lo CC libmonoruntimesgen_static_la-sysmath.lo CC libmonoruntimesgen_static_la-threads.lo CC libmonoruntimesgen_static_la-threadpool.lo CC libmonoruntimesgen_static_la-verify.lo gcc: internal compiler error: Killed (program cc1) Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions. make[3]: *** [libmonoruntimesgen_static_la-verify.lo] Error 4 make[3]: Leaving directory `/root/mono-3.6.0/mono/metadata' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/root/mono-3.6.0/mono' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/root/mono-3.6.0' make: *** [all] Error 2 There were several (10-15) warnings along the way, but I'm guessing at this point there's not much point in digging into it deeper.Any update on whether mono runtime can be installed on armv5tel CPU?
Luke 42245 Posted October 13, 2017 Posted October 13, 2017 I'm not sure we've tried that architecture to be honest.
Jdiesel 1437 Posted October 13, 2017 Posted October 13, 2017 Does it really only have 128mb of RAM? I don't think that is going to cut it.
mastrmind11 722 Posted October 13, 2017 Posted October 13, 2017 Have you tried the .Net core version? Also, as @@Jdiesel pointed out, those pogoplugs are sooorly underpowered for this.
tdiguy 99 Posted October 13, 2017 Posted October 13, 2017 Personally i suspect that if you are able to get everything installed that you will not be able to transcode at all. I cant really speculate on playing compatible formats like mp4's since that is generally a low cpu usage type of thing, but i have had problems getting transcoding to play smoothly using a pi3. If there isnt a compatible version of mono you might try the .net version which is in the testing area ( as others have said ) but yea that board might be very challenged to run emby server. A pi3 can run emby server and can transcode ( once you get ffmpeg compiled to support hardware acceleration ) ( not exactly smooth but it can do it ).
huge 0 Posted October 13, 2017 Author Posted October 13, 2017 Thanks for the replies - sounds like I should drop this ambition until I get myself a more grown-up server, or just install on my (Windows) HTPC & give up on serving the whole house.
mastrmind11 722 Posted October 13, 2017 Posted October 13, 2017 Thanks for the replies - sounds like I should drop this ambition until I get myself a more grown-up server, or just install on my (Windows) HTPC & give up on serving the whole house. Out of curiosity, why wouldn't you be able to serve the whole house if running on your HTPC?
tdiguy 99 Posted October 13, 2017 Posted October 13, 2017 Well some things to consider, when it comes to the whole house, how many devices are you talking? Would this be for streaming live tv also or just already recorded movies? If its for movies are they already in a streaming friendly format like mp4 or mkv? Transcoding even on an optimized setup is going to likely be the most cpu intensive task. If you dont need to transcode and your files are already in a stream friendly format a pi2 has the horsepower to stream to a few devices at once a pi3 of course even more of them.
huge 0 Posted October 17, 2017 Author Posted October 17, 2017 Out of curiosity, why wouldn't you be able to serve the whole house if running on your HTPC? Mostly I meant because I don't currently have the HTPC turned on 24/7, and because it's an old Windows 7 machine that isn't particularly low-power and isn't designed to operate as a server. Well some things to consider, when it comes to the whole house, how many devices are you talking? Would this be for streaming live tv also or just already recorded movies? If its for movies are they already in a streaming friendly format like mp4 or mkv? Transcoding even on an optimized setup is going to likely be the most cpu intensive task. If you dont need to transcode and your files are already in a stream friendly format a pi2 has the horsepower to stream to a few devices at once a pi3 of course even more of them. Most of my video watching is recorded mp4 or mkv. The ideal response to both comments would be for me to build a new combo NAS/HTPC ... something I'd like to do eventually, maybe soon
tdiguy 99 Posted October 17, 2017 Posted October 17, 2017 If your not going to need to transcode a pi will work well for now. I forget which ones but if you buy a nas solution some of them can have emby installed on them.
