Crestj 68 Posted January 25, 2014 Posted January 25, 2014 Has anyone managed to do this so I can move my MCM to a new server? The MCM forums don't seem to have info on this. Sent from my Nexus 5 using Tapatalk
CBers 7554 Posted January 25, 2014 Posted January 25, 2014 Still using MCM? Not sure Pete has a setting for exporting, but all of the settings are in the registry, so you could try exporting just his part to a file, or all of it and just take his bit out, save as a .reg file then import on new PC. Or, just copy and paste entries from one to another. That's how I did it in the past.
Crestj 68 Posted January 25, 2014 Author Posted January 25, 2014 (edited) Yeah, tbh if MBserver could pick up movies and TV episodes and move them to the right places based on their meta data I'd bin mcm in a flash. Time to delve in the registry then. Cheers Sent from my Nexus 5 using Tapatalk Edited January 25, 2014 by Crestj
CBers 7554 Posted January 25, 2014 Posted January 25, 2014 Do you not use SickBeard/CouchPotato? I think moving and renaming will come to MB3 at some point.
Crestj 68 Posted January 25, 2014 Author Posted January 25, 2014 Tried those but found utorrent on a private tracker easier for those legal downloads. Sent from my Nexus 5 using Tapatalk
trusselo 225 Posted January 25, 2014 Posted January 25, 2014 copy this folder to your new machine. C:\Users\USER\AppData\Roaming\Peter Souza IV\Media Center Master make sure to de-authorize and revoke registration on old machine first. (if aplicable) 1
