horstepipe 423 Posted December 1, 2016 Posted December 1, 2016 hey what is the safest/correct way to switch from Emby server stable to beta release on a headless ubuntu machine? Thanks in advance
sscheib 11 Posted December 1, 2016 Posted December 1, 2016 Backup /var/lib/emby-server/ and run apt-get install emby-server-beta. Everything should go fine, but in case something fails you have your backups from /var/lib/emby-server 1
horstepipe 423 Posted December 2, 2016 Author Posted December 2, 2016 Backup /var/lib/emby-server/ and run apt-get install emby-server-beta. Everything should go fine, but in case something fails you have your backups from /var/lib/emby-server worked as expected, thank you!
Luke 42244 Posted December 2, 2016 Posted December 2, 2016 Please note, we don't recommend switching the same server installation between release channels, but I'm glad it went well for you. Thanks. 1
