fvboegeld 1 Posted November 30, 2016 Posted November 30, 2016 Hi, I had to remove mono for some specific reasons and did (stupid.. so yeah i know..) a purge of anything related to mono. I was able to reinstall mono but now whenever i'm trying to install emby (dev and stable) i get the following error : sudo apt-get install emby-server-dev Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server-dev : Depends: libembysqlite3-0 but it is not installable Depends: embymagick but it is not installable anyone knows how to solve this? Thanks!
Luke 42240 Posted November 30, 2016 Posted November 30, 2016 Hi there, what repository are you using? Did you follow the instructions on our website? http://emby.media/download
fvboegeld 1 Posted November 30, 2016 Author Posted November 30, 2016 Luke... I made this post in the wrong forum... Its on raspberry so i should have posted it in the Linux section.. Sorry about that
fvboegeld 1 Posted November 30, 2016 Author Posted November 30, 2016 Thanks.. Well, the first install i was already following the procedure you mention in the download section and it worked flawless.. Now that i did the "sudo apt-get purge mono-complete", i can't seem to follow the same procedure anymore.. Always comes back that emby-server-dev has some unmet dependencies : libembysqlite3-0 and embymagick... But those are for some reason not installable anymore...
Luke 42240 Posted November 30, 2016 Posted November 30, 2016 have you tried apt-get update to update your package cache?
fvboegeld 1 Posted December 1, 2016 Author Posted December 1, 2016 yea.. tried several commands but at no luck... are those normally packages that are installed when installing emby?
fvboegeld 1 Posted December 1, 2016 Author Posted December 1, 2016 ok.. seems to be the same problem as the one mentionned in this post : https://emby.media/community/index.php?/topic/19415-debian/page-10&do=findComment&comment=390662 the reason why i had to reinstall mono was because of a mono update that messed up a couple of things... What i did to solve it was : Download embymagick_6.9.6+6-3.1_armhf.deb and libembysqlite3-0_3.15.0+1-6.1_armhf.deb from the ubuntu binaries and then install with sudo dpkg -i <deb file> At least now i'm able to install emby dev
