Nathanio 35 Posted November 30, 2016 Posted November 30, 2016 Running v2.8.24 on an LG G4 v6.0 Marshmallow. When playing live TV through the app, if I get a notification it mutes the audio on the app but doesn't then re-enable after the notification stops. I can re-enable the audio by going and select the second audio track and then the first again. However, not all the channels have a second track and so then requires stopping and starting the track. I don't believe this happens when playing a h264, aac file. 1
Luke 42243 Posted November 30, 2016 Posted November 30, 2016 I've never seen this before. I would ensure the volume on the device isn't turned down when this happens.
Nathanio 35 Posted November 30, 2016 Author Posted November 30, 2016 I've never seen this before. I would ensure the volume on the device isn't turned down when this happens. Already checked that. Video plays fine still. The only way to get it back is to switch audio track or stop restart the stream.
rikiwi 32 Posted December 1, 2016 Posted December 1, 2016 I've been getting this too, not sure when it started Sent from my D6653 using Tapatalk
Nathanio 35 Posted December 1, 2016 Author Posted December 1, 2016 Other media playing apps such as mx player, Google play music etc don't exhibit the behaviour
psubsee2002 7 Posted December 2, 2016 Posted December 2, 2016 (edited) It is not just live TV. I've seen this with playback of any media. When a notification (with sound) occurs, the audio stream gets very soft for half a second then cuts out completely. Previously the audio stream would get soft when there was a notification but would resume as normal half a second later. It is not device specific as my wife and I are experiencing this on 2 Galaxy S6's and a Zenpad Z8. We're both running v2.8.27 on all 3 devices according to Google Play ( which doesn't quite makes sense since I am using the beta version and she isn't). This is relatively recent (within the last 30 days) Edited December 2, 2016 by psubsee2002
Luke 42243 Posted December 2, 2016 Posted December 2, 2016 Thanks for the report. We'll look into it.
