Michael K. 24 Posted November 27, 2016 Posted November 27, 2016 Hello, While watching TV episodes, I have noticed that audio will skip(repeat about 1 second of audio), which causes the audio to fall out of sync with the video. I haven't noticed any particular pattern to this. It seems like it happen at random times. I believe it occurs once per episode. To fix it, I have to stop the episode and then resume. Once I resume, everything is fine until the end of the episode. Once the next episode starts automatically, the tends to happen again. Has anyone else experienced this? Log files attached. Please advise. Thanks! -Michael server-63615801600.txt ffmpeg-transcode-f7c3223e-a1ee-496d-b47b-33a653a5c2b3.txt
Michael K. 24 Posted November 28, 2016 Author Posted November 28, 2016 I notice the error becoming more severe. While watching an episode, the audio skipped multiple times within a few seconds. This caused the audio to become out of sync by a few seconds. ffmpeg-transcode-0947a06a-c4f2-4d4b-896a-f5ac2f71d5b3.txt server-63615801600.txt
Luke 42242 Posted November 28, 2016 Posted November 28, 2016 Hi, when the next release of Emby Server is available, please try again and let us know how that compares. thanks !
Michael K. 24 Posted November 28, 2016 Author Posted November 28, 2016 Okay, I'll keep you posted, thanks.
Michael K. 24 Posted December 29, 2016 Author Posted December 29, 2016 (edited) The issue still exists for me in Emby Server 3.1.2.0. Note: While I was troubleshooting an unrelated issue, I noticed that this issues does not happen when Transcoding hardware acceleration (Intel Quick Sync) is enabled. Edited December 29, 2016 by Michael K.
Luke 42242 Posted December 29, 2016 Posted December 29, 2016 Is this only after a seek? If you just watch the video from beginning to end, do you see the problem?
Michael K. 24 Posted December 29, 2016 Author Posted December 29, 2016 Is this only after a seek? If you just watch the video from beginning to end, do you see the problem? It happens when I watch from beginning to end. It's never happened to me when using seek.
Luke 42242 Posted December 29, 2016 Posted December 29, 2016 Well your transcode logs are from a seek (or resume), so that's why I asked.
Michael K. 24 Posted December 29, 2016 Author Posted December 29, 2016 Well your transcode logs are from a seek (or resume), so that's why I asked. I suspect in that case when i pressed play that it asked me if I wanted to resume or start from the beginning - which I selected start from beginning. I just watched an episode again today and the issue happened while I played from beginning to end. I will watch a few more episodes from beginning to end and post new log files.
Michael K. 24 Posted December 30, 2016 Author Posted December 30, 2016 Here are the new log files. I restarted the server and I then began playing an unwatched episode from the beginning. About 4:17 seconds into the episode, the audio skipped(repeated on second of sound), causing it to fall out of sync with the video. A few minutes later I stopped playback and saved all logs surrounding the event. ffmpeg-transcode-3eadcc3d-edde-4d4f-bd53-8f716c5b3d39.txt ffmpeg-transcode-81579c55-913e-4c80-9fc5-26ff7f2b463e.txt ffmpeg-transcode-bae66e15-f4e4-4fda-a186-85611c3c36f0.txt server-63618650842.txt server-63618652800.txt
