Z0m8ie 26 Posted November 27, 2016 Posted November 27, 2016 Im using Emby inside WMC and cannot play any trailers at all. When I choose a trailer to play it simply doesn't play or it loads the trailer frame by frame very slowly.
Happy2Play 9801 Posted November 27, 2016 Posted November 27, 2016 Netflix has been that way for awhile. https://emby.media/community/index.php?/topic/33968-trailers-plugin-not-showing-netflix-trailers/ https://emby.media/community/index.php?/topic/33831-trailer-plugin/ You will need to post logs for when you tried to play a trailer.
Z0m8ie 26 Posted November 27, 2016 Author Posted November 27, 2016 Netflix has been that way for awhile. https://emby.media/community/index.php?/topic/33968-trailers-plugin-not-showing-netflix-trailers/ https://emby.media/community/index.php?/topic/33831-trailer-plugin/ You will need to post logs for when you tried to play a trailer. Attached are the logs after trying to play "Bad Santa 2" and "The Arrival". server-63615855534.txt
Z0m8ie 26 Posted November 27, 2016 Author Posted November 27, 2016 I hope these are the correct logs you are talking about...
Happy2Play 9801 Posted November 27, 2016 Posted November 27, 2016 Do you get the same results in the web client?
Z0m8ie 26 Posted November 27, 2016 Author Posted November 27, 2016 (edited) Do you get the same results in the web client? Yup, spinning disc... Edited November 27, 2016 by Z0m8ie
Happy2Play 9801 Posted November 27, 2016 Posted November 27, 2016 I can play Bad Santa 2 via the plugin but don't have The Arrival listed at all. But just noticed you are on DEV version so will have to check another machine.
Happy2Play 9801 Posted November 27, 2016 Posted November 27, 2016 I guess it is there but just "Arrival". Got a spinning circle for about 3 seconds then trailer started. That test machine is busy doing other stuff on slow hard drive to that is a expected result for me.
Z0m8ie 26 Posted November 28, 2016 Author Posted November 28, 2016 I guess it is there but just "Arrival". Got a spinning circle for about 3 seconds then trailer started. That test machine is busy doing other stuff on slow hard drive to that is a expected result for me. I get either the spinning disc or the first few frames of the trailer then nothing... What should I do?
Happy2Play 9801 Posted November 28, 2016 Posted November 28, 2016 Is there a Transcode or directstream log created? If so can you post. Is there a reason for running Dev version?
Z0m8ie 26 Posted November 28, 2016 Author Posted November 28, 2016 (edited) Is there a Transcode or directstream log created? If so can you post. Is there a reason for running Dev version? No there is no reason for running the Dev version its just the one I picked when I originally installed MB3 a long time ago. Im a premium member if that helps at all. Edited November 28, 2016 by Z0m8ie
Z0m8ie 26 Posted November 28, 2016 Author Posted November 28, 2016 Here is the latest ffmpeg-directstream log. ffmpeg-directstream-f077ffa9-05db-4806-b131-3bbd54728145.txt
Happy2Play 9801 Posted November 28, 2016 Posted November 28, 2016 Can you post a full server log showing your issue, the log posted above doesn't even show the trailers being played.
Luke 42186 Posted November 28, 2016 Posted November 28, 2016 If you'd like to do some comparison with the portable stable server installation, that would be helpful. For context, since you are running a testing build I am assuming you're interested in participating in that type of activity. Thanks.
