GollyJer 17 Posted November 25, 2016 Posted November 25, 2016 Can someone verify that Settings -> Appearance -> File Lists -> Ignore articles when sorting works? I'm actually trying to turn it OFF. It works for people in the Kodi forum.I want The Americans and The Daily Show and The Big Bang Theory to sort together but turning "ignore articles" off has no affect. I tested with Kodi 16.1 and the latest 17 nightlies with the same result.If it's not Emby for Kodi then I'm at a complete loss. :-/ Thanks!
Solution Happy2Play 9811 Posted November 25, 2016 Solution Posted November 25, 2016 Probably do to Emby having those "SortRemoveWords" some what built in. You would have to shutdown server and navigate to the system.xml and remove "the" string. C:\Users\username\AppData\Roaming\Emby-Server\config\system.xml <SortRemoveWords> <string>the</string> <string>a</string> <string>an</string> </SortRemoveWords> 2
GollyJer 17 Posted November 26, 2016 Author Posted November 26, 2016 That was it! Thanks! I shut down Emby Server, removed that line from the system.xml, went into Emby for Kodi settings, Reset the database, closed Kodi, reopened and waited for the database to rebuild. Now things are sorting how I want! Thanks again. 1
