mfreesto 0 Posted November 25, 2016 Posted November 25, 2016 I am running Version 3.0.8500.0 on a Ubuntu server. I am using Schedules Direct for Guide data. My Guide is missing a lot of data (It has many blank spots in it.) I have tried refreshing but it doesn't help.
Luke 42244 Posted November 27, 2016 Posted November 27, 2016 Hi, if you refresh the guide again, is it still happening today?
mfreesto 0 Posted November 27, 2016 Author Posted November 27, 2016 Unfortunately, yes. Same problem. Any suggestions? Thanks!
Luke 42244 Posted November 27, 2016 Posted November 27, 2016 What zip code and lineup did you select from schedules direct?
mfreesto 0 Posted November 28, 2016 Author Posted November 28, 2016 (edited) 84081. Comcast - Digital. Edited November 28, 2016 by mfreesto
Luke 42244 Posted November 28, 2016 Posted November 28, 2016 What zip code and lineup did you select from schedules direct?
mfreesto 0 Posted November 28, 2016 Author Posted November 28, 2016 I added that to my previous note later (assuming by lineup you mean Comcast - Digital.) See also the attached screenshot.
Luke 42244 Posted November 30, 2016 Posted November 30, 2016 I tested your lineup and I have a complete guide. I only tested mapping two channels - MTV Live and the golf HD channel. They both have empty slots in your screenshot so they looked like good cases to try. I stepped through all 14 days of guide data and didn't see any issues. If you're still seeing the issue, then I would suggest testing again with the next release of Emby Server. Thanks !
mfreesto 0 Posted December 1, 2016 Author Posted December 1, 2016 I looked again this morning and interestingly most (not quite all) of the gaps are now filled in. Where there are gaps it is a few stations that have no shows listed at all. From what I can tell the rest of the channels are completely filled out. I am still running I am running Version 3.0.8500.0. Thought you might be interested to know.
