Mopar_Mudder 14 Posted November 25, 2016 Posted November 25, 2016 Ok I want to try my hand at making a plugin which I have no experience with. I have done some basic Visual Basic stuff in Excel and some programing on an Arduino. So I downloaded Visual Studio 2015 and tried following https://github.com/MediaBrowser/Emby/wiki/How-to-build-a-Server-Plugin to get started. I get an error while loading the nugget, from some other post is sounds like the guide might be out of date and not correct anymore. So is their a better place to go to get started?
Luke 42237 Posted November 25, 2016 Posted November 25, 2016 Hi, welcome. What kind of plugin are you planning to build?
Mopar_Mudder 14 Posted November 25, 2016 Author Posted November 25, 2016 I want to play certain files and possibly trigger IR commands before a movie starts in Emby Theater.
Luke 42237 Posted November 25, 2016 Posted November 25, 2016 Ok well I updated the first part of the plugin wiki which needed to be updated. It's just about creating the project and what targeting should be selected.
Mopar_Mudder 14 Posted November 25, 2016 Author Posted November 25, 2016 Thanks, I will play around with it some more and see what I can do.
