zebo51 22 Posted November 25, 2016 Posted November 25, 2016 I have a 2015 samsung smart tv and installed the app from the app store. I got it connected to my server and so far so good. I started playing a show and the bottom menu or status window won't go away. I have tried up/down arrows, return button, exit button, info, tools. Return exits the emby app or maybe exit does. Either way neither of those work. Right/left arrows go between FF/FR and pause/play. I have searched google and these forums for Emby App controls and buttons. I found a few post in beta release notes but I can't find a list of what all buttons should do what, does this exists? Using the Samsung remote that came with the TV. UN40JU6400 Thanks
