NeauxGeaux 9 Posted November 23, 2016 Posted November 23, 2016 I don't see Emby in the Smart Hub.. or am I missing something?
FrostByte 5453 Posted November 24, 2016 Posted November 24, 2016 The app is only available in the US att, but assuming your local time is correct that may not be the issue. Not all Tizen TVs support all APIs. I believe I read in the Samsung forum that only the J5500 and greater will work with for instance the remote control API. If so that could be why you're not seeing it. Luke or Ebr would have to confirm though why it isn't working with your entry level tv https://www.samsungdforum.com/Tizen/Spec#TVModelLineup 1
Luke 42240 Posted November 24, 2016 Posted November 24, 2016 If that model is in the entry level family then it's not available yet. I hope to request testing for that next week once the current pending release clears. 2
NeauxGeaux 9 Posted November 24, 2016 Author Posted November 24, 2016 Ahh, ok I didn't know that. Thanks for the clarification! This is the first TV upgrade I've bought in a long time so I wasn't really sure. I should have spent the extra $60 for the J6200 (?) model then! @Luke: when you say 'request testing next week', does that mean I could potentially be in luck for getting an official Emby app on this TV? I just tried the built in browser using tv.emby.media and I sadly must say that it even though Emby looks fantastic, it's just not very easy to navigate with the tv remote! Looking forward to hearing more updates!
Luke 42240 Posted November 24, 2016 Posted November 24, 2016 For some reason Samsung does not include entry level in the default model set so that is why it's not included yet. The Samsung app portal only lets us do one thing at a time so requesting testing for entry level models has just been waiting it's turn in line.
NeauxGeaux 9 Posted November 25, 2016 Author Posted November 25, 2016 Gotcha. Thanks for the reply. I got another chromecast as a temporary solution for now. Look forward to hearing more updates! Have a great Thanksgiving weekend!
NeauxGeaux 9 Posted December 7, 2016 Author Posted December 7, 2016 For some reason Samsung does not include entry level in the default model set so that is why it's not included yet. The Samsung app portal only lets us do one thing at a time so requesting testing for entry level models has just been waiting it's turn in line. Luke, any updates on the j5200 model? Thank you
Luke 42240 Posted December 7, 2016 Posted December 7, 2016 A regression was introduced in 1.0.15 for a couple models: https://emby.media/community/index.php?/topic/41865-samsung-6-series-ku6300-seek-bar-wont-go-away-no-config/ Due to this issue we are first issuing 1.0.16 to correct that, then once that's complete we'll request testing from Samsung for entry level models. 1
Dalboz 0 Posted December 21, 2016 Posted December 21, 2016 (edited) Any update on this? I recently got a J5200.. Edited December 21, 2016 by Dalboz
chazgee 0 Posted December 29, 2016 Posted December 29, 2016 I just got a J6200. Also don't see the Emby App available on any screen. Would love any info on using Emby with this TV. Thanks!
digger11 1 Posted January 3, 2017 Posted January 3, 2017 @@Luke Any news on testing for entry level models? I'm assuming that still hasn't happened as we couldn't find the Emby app on a UN32J5205.
Luke 42240 Posted January 3, 2017 Posted January 3, 2017 Not yet, but see here for a nice trick to install on your device: https://emby.media/community/index.php?/topic/27254-status-of-tizen/?p=401993
FrostByte 5453 Posted January 3, 2017 Posted January 3, 2017 Ya, but that doesn't help those who are in USA As the plot thickens 1
taylorbourne 19 Posted January 3, 2017 Posted January 3, 2017 I'm confused.. so the un55j6200 should be able to install Emby? I don't see it when searching. I'm also in the US.
FrostByte 5453 Posted January 3, 2017 Posted January 3, 2017 I'm confused.. so the un55j6200 should be able to install Emby? I don't see it when searching. I'm also in the US. So is Luke it appears Those procedures are only for people with upper end Tizen devices who live outside the US to temporarily get around the country check. There is still a problem with entry level sets in the US (and most likely Worldwide) also. There are two issues at hand that they are still waiting for Samsung to approve.
Luke 42240 Posted January 3, 2017 Posted January 3, 2017 The Samsung dev portal doesn't let me select his model group. i will have to contact them for explanation. Is it possible that even though it is labeled a Tizen tv that it is using the older Samsung app store? That might be the reason why. 1
NeauxGeaux 9 Posted January 6, 2017 Author Posted January 6, 2017 (edited) Not yet, but see here for a nice trick to install on your device: https://emby.media/community/index.php?/topic/27254-status-of-tizen/?p=401993 So will this actually work in the U.S. ? Edit: nevermind, I was misunderstanding. I wonder why/if they would use an older app store on this particular model.. so weird. I guess this is a lost cause? Edited January 6, 2017 by NeauxGeaux
Luke 42240 Posted January 6, 2017 Posted January 6, 2017 Yea it looks like that model group is using the older SDK. 1
