CharleyVarrick 284 Posted March 22, 2017 Author Posted March 22, 2017 It's been 6.5 hours and under Romance genre I am now down to 6 tv series ( I had 12 earlier). This after refreshing.
CharleyVarrick 284 Posted March 22, 2017 Author Posted March 22, 2017 Not seing any more progress, I scan libraries and the genre I deleted this morning was gone as soon as the scan was over.
Happy2Play 9814 Posted March 23, 2017 Posted March 23, 2017 @@Happy2Play have you seen this? @@Luke I just removed Romance (TV) in Genre cleaner and click Save and then Start Library Scan and library scan took 4 minutes and 17 seconds and removed Romance genre that had 5 series listed before library scan.
CharleyVarrick 284 Posted March 23, 2017 Author Posted March 23, 2017 Ok, so we do need to scan library (every libraries) each time we use genre cleaner Is the scan library step mandatory?
Luke 42252 Posted March 23, 2017 Posted March 23, 2017 Yes, a library scan is needed, or you can just wait for the next scheduled scan because it doesn't have to happen immediately.
Happy2Play 9814 Posted March 23, 2017 Posted March 23, 2017 Ok, so we do need to scan library (every libraries) each time we use genre cleaner Is the scan library step mandatory? The plugin explicitly says that. Once you have configured all your genres, the next library scan will run the GenreCleaner against all your items.
