Poster wall for TV not working
Go to solution Solved by space2001,
Not showing the poster just the names.
Koleckai Silvestri
Can't recreate this. Do you have posters assigned to your television shows in the metadata editor?
That is what my poster wall works for. There is no poster for "Beyond the Movie". I should add one but keep forgetting.
Here is the poster strip showing the posters
Here is the poster wall not showing them.  Unless I am missing something.
Koleckai Silvestri
No, it should automatically pull them. Are you using version 3.0.5129.37166?
Version 3.0.5135.31685 was just posed might try that version.  Unless you running a dev build higher in which case you might want to switch to beta.
Koleckai Silvestri
For Media Browser Theater? I have the version you posted above for Server but not getting an update notification for Media Browser Theater. I posted the Theater version... I have server set to update at beta and theater set to update at dev levels.
Edited by Wayne Luke
  • Solution
I re-install Theater now the images are appearing.
