DGMayor 90 Posted January 23, 2014 Posted January 23, 2014 Title says it all. It's small, but you can see the banner is being treated with the boxset setting.
ebr 16343 Posted January 24, 2014 Posted January 24, 2014 Can you find the log where that treatment was actually created?
ebr 16343 Posted January 24, 2014 Posted January 24, 2014 Never mind. I reproduced it. I think we just have never had banners for box sets before.
Solution ebr 16343 Posted January 24, 2014 Solution Posted January 24, 2014 Update to the beta I just put up (4.0.5.0). Unfortunately, you'll have to manually delete the enhanced images that were created before but any new ones should be correct now. 1
DGMayor 90 Posted January 25, 2014 Author Posted January 25, 2014 Didn't even see your request until you had already solved it
