bozrdnag 75 Posted November 22, 2016 Posted November 22, 2016 I have two libraries; Movies and TV shows and here is how they are setup: Untitled by rockdawg2232, on Flickr Untitled by rockdawg2232, on Flickr The problem I am having is that the path showing for movies in the metadata manager is different: Untitled2 by rockdawg2232, on Flickr For one, I'm not sure why it's showing 192.168.1.42 rather than /mnt in the path. It has been suggested that it's because of the Path Substitution I am using, but if I change it to something else the paths in the metadata manager don't change along with my edit. But the big issue is the that the slashes are sometimes reversed in the path listed in the metadata manger. You can see from my first 2 pics that the Path Substitution is using \\192.168.1.42\ but the 3rd pic shows the metadata manager listing //192.168.1.42/. For some reason I am only seeing this with my movies. All the TV episodes I checked have the slashes going the right way. The reversed slashes are causing me problems in Emby for Kodi as any video with the wrong slash will not play and throws an error.
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 It is running in a Docker container and the version is 3.0.8500.0
Luke 42186 Posted November 22, 2016 Posted November 22, 2016 It is showing your path after path substitution.
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 OK,but why is it reversing the slashes sometimes? And if I want to change the path substitution, how do I get he change to be reflected in the Metadata manager?
Luke 42186 Posted November 22, 2016 Posted November 22, 2016 check the old path substitutions config, maybe you have an old one hanging around there.
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 Where do I check that at? I never had anything configured under the old Path Substitution. I just configured for the first time with the new Shared Network Folder field.
Happy2Play 9801 Posted November 22, 2016 Posted November 22, 2016 Check " <PathSubstitutions>" in your system.xml (\Emby-Server\config)
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 All it shows in there is: <PathSubstitutions /> Nothing else there. system.xml
Luke 42186 Posted November 22, 2016 Posted November 22, 2016 Ok, is there an actual problem occurring?
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 Yes. As I said in the first post, the slashes are reversed on a lot of my videos and every file that's like that won't play with Emby for Kodi. 1
Logos302 86 Posted November 22, 2016 Posted November 22, 2016 The only one that should matter is the first two everything else slash wise are interchangeable (for the most part). This doesn't help you other that the error is in the first two slashes they are pointed in the wrong direction. Which does look like a bug to me.. Do you have an example of what your TV sub look like? Just to compare.
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 Here is the path to a TV epiosde with the slashes going in the correct dirrection: Untitled5 by rockdawg2232, on Flickr
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 (edited) It is showing your path after path substitution. Then what needs to be done to refresh the paths. Because I can go and change the path substitution and the metadata manager shows the same old path. I've even tried removing the path substitution and the path doesn't change in the metadata manager. Rebooting the server doesn't do it either All it shows in there is: <PathSubstitutions /> Nothing else there. Is that the way it should read in the system.xml? Edited November 22, 2016 by bozrdnag
Happy2Play 9801 Posted November 22, 2016 Posted November 22, 2016 Yes ^^ The New way writes to Library folder "\Emby-Server\root\default\Movies\options.xml". Is it written wrong there?
bozrdnag 75 Posted November 22, 2016 Author Posted November 22, 2016 (edited) It is written correctly in "\Emby-Server\root\default\Movies\options.xml". What makes the actual paths update with any changes because that's not happening. I can change the path substitution to anything and the the paths stay exactly as I showed in my original post. I was hoping that making I could change them to something wrong and then change them back to the correct to sort of "refresh" the paths but nothing changes them. Edited November 22, 2016 by bozrdnag
Happy2Play 9801 Posted November 22, 2016 Posted November 22, 2016 Do all movie Libraries share this issue? Or just the one?
Happy2Play 9801 Posted November 22, 2016 Posted November 22, 2016 I guess I mean folder paths since this is one library. So are DVD, Blu-Rays, HD Rips, ... doing the same thing.
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 Yes. They all do it. But my TV Shows are all fine.
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 Any suggestion on where to go from here so I can get my movies working in Kodi?
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 I just tried removing the entire Movies library, then ran a Clean Library, recreated the Movie library adn let it scan, and it still has the slashes reversed.
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 Also, nobody has answered this question yet... What mechanism causes the paths to be updated to the entry in the Shared Network Folder Field. I also did the above with my TV shows but when I recreated the library I left the Shared Network Folder field empty. Once scanning was complete I went in and added \\192.168.1.42\... and the paths in the metadata manager still show /mnt/... How can I force an update?
Happy2Play 9801 Posted November 23, 2016 Posted November 23, 2016 For me on Windows the change in instant. If I fill in "(Optional) Shared network folder:" information, that is what is displayed in path. If I remove it, then Physical folder path is displayed. Since you are not using Windows is there a issue with your version?
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 (edited) If I change that nothing changes. Apparently it did once, but now that I'm looking for it, nothing changes. I have no idea if there's a problem with my version. I would assume so since it sure doesn't seem to be acting right. I was hoping you guys could tell me that. I know my Emby is from the official Emby Docker repo. Edited November 23, 2016 by bozrdnag
bozrdnag 75 Posted November 23, 2016 Author Posted November 23, 2016 (edited) Something just dawned on me and I am wondering if it's at least part of the problem. I share my videos with friends and family via Emby and they want some stuff that I don't like and don't want in my library. In an attempt to simplify things for them and make it so they only have one movie folder on their Roku home screen I created 2 libraries: Movies (for me) and All Movies (for them). Their library contains all the same paths as mine and includes an additional one that contains all the movies they like but I don't want. Here's how I have them set up: Movies /mnt/Videos/Movies/Blu-Ray /mnt/Videos/Movies/Blu-Ray Atmos /mnt/Videos/Movies/DVD /mnt/Videos/Movies/HD Rips All Movies /mnt/Videos/Movies/Blu-Ray /mnt/Videos/Movies/Blu-Ray Atmos /mnt/Videos/Movies/DVD /mnt/Videos/Movies/HD Rips /mnt/Videos/Movies/Outside Movies I just realized that in the beginning of all this I accidentally started setting up the path substitution on the All Movies library and missed typed with the wrong slashes. So that must have been where it was getting the path with the backwards slashes for the movies. I have now deleted those path substitutions and my paths immediately switched to /mnt/Videos/Movies/Blu-Ray/300/300.mkv in the metadata manager. The problem is that I still have path substitutions set as \\192.168.1.42\Videos\Movies\Blu-Ray in the Movies library. Why didn't they switch to that? So now my question is... is that an incorrect way to setup my libraries and it's confusing Emby? Edited November 23, 2016 by bozrdnag
