lolwut 16 Posted January 23, 2014 Posted January 23, 2014 Hi @@ScottIsAFool, WP7.8 <-> Server <-> MBT connection has sync problems (WP7.8, Server+MBT are on the same network) Examples: Remote page is empty after you start playing an item on MBT or Web Client. You need to hit refresh few times to get it working. When You pause an item, the pause button shows instead of play. You need to hit refresh for it to show play button. It shows the previous item playing on the MBT unless you hit refresh. You need to hit refresh few times to show new clients that joined to server recently. Basically, You need to hit refresh before and after everything you do to remote control to show correct info and work. Doesnt server send some kind of notification back after a state change, so app refreshes automatically, or doesnt app have some kind of refresh timeout after an event? I am asking this because maybe app is working correctly and my network is blocking these notifications and messing with app functionality Anyway, can you please look into it? Cheers BTW, Still waiting on video playback on WP7.8
ScottIsAFool 517 Posted January 24, 2014 Posted January 24, 2014 It should do, yes. You're not the first to report this and I am investigating the issue.
