I have gotten TV up and its great!  Well done! One step closer to ditching WMC as a front-end (Oh Happy days!)
While its only via the web atm, I understand that the HD quality will be not be up to the same levels as WMC being dumped via HDMI right out to your TV. I would assume that when its integrated into MBT / MBC that it will be at higher quality since all the tanscoding will be done on the machine that is pumping it out to the TV, which will offload it from the backend and it will not have to transcoded into a web-enabled format? Forgive me if I have this all wrong, I am a poor code monkey, not an AV guy (yet).
