iam4uk 26 Posted January 23, 2014 Posted January 23, 2014 I installed serverwmc today after updating MB3 server and seeing the "Live TV" section. ServerWMC is running and its interface reports that all is well, but MB3Server reports "serverwmc not connected." I have not found documentation or troubleshooting tips for this exciting new additional capability; can anyone point me in the right direction? Windows 7 Home Premium x64 SP1 intel i5-2500K, 8 GB RAM nvidia GT 430, driver 332.21 Media Browser Server 3.0.5135.31685, running on ports 8096 and 8945 (I noticed a reference to port 9080 for serverwmc, but have not found any option for specifying any ports in MBServer.)
Logos302 86 Posted January 23, 2014 Posted January 23, 2014 I could be wrong but I believe there is a special version of ServerWMC for MB3 that needs to be installed and not just the regular one. you will also need to supply logs from the server before they will be able to help.
robsch 45 Posted January 24, 2014 Posted January 24, 2014 (edited) I installed serverwmc today after updating MB3 server and seeing the "Live TV" section. ServerWMC is running and its interface reports that all is well, but MB3Server reports "serverwmc not connected." I have not found documentation or troubleshooting tips for this exciting new additional capability; can anyone point me in the right direction? Windows 7 Home Premium x64 SP1 intel i5-2500K, 8 GB RAM nvidia GT 430, driver 332.21 Media Browser Server 3.0.5135.31685, running on ports 8096 and 8945 (I noticed a reference to port 9080 for serverwmc, but have not found any option for specifying any ports in MBServer.) The port is correct... If you go into Plugins -> ServerWMC (On your MB3 server) The port and the ServerWMC/IP Name filed should be there. If its hosted on the same machine, try setting it to 127.0.0.1, otherwise use the IP address of the machine that has the TV Tuner and ServerWMC on it. Also, make sure that you have serverWMC running BEFORE you start up MB3... As @@Logos302 said, please post your logs if checking those things don't help. Edited January 23, 2014 by robsch 1
iam4uk 26 Posted January 24, 2014 Author Posted January 24, 2014 Thanks, will check... Sent from my SCH-I545 using Tapatalk
pagali 62 Posted January 24, 2014 Posted January 24, 2014 The thing that caught me unawares was the need to have WMC already set up for Live TV, recognizing your tuner, channels, downloading guide information, etc. If this isn't done already, ServerWMC apparently won't have anything to connect to, since it's just a connection between WMC and MB3. If you've already done all this, please ignore.
iam4uk 26 Posted January 24, 2014 Author Posted January 24, 2014 I followed the guidance of robsch and it worked. The MBServer plugin had been set to "localhost," which did not work, so I input the IP address of the computer. Now serverwmc live tv is working, but what can be done with it? I don't see it in MediaBrowser on my computer or android app.
Luke 42287 Posted January 24, 2014 Posted January 24, 2014 Only the web client has support for live tv right now. The other developers are all working on it.
iam4uk 26 Posted January 24, 2014 Author Posted January 24, 2014 Thank you, Luke. I am enthused by the direction of the development of MediaBrowser. Sent from my SCH-I545 using Tapatalk
robsch 45 Posted January 24, 2014 Posted January 24, 2014 I followed the guidance of robsch and it worked. The MBServer plugin had been set to "localhost," which did not work, so I input the IP address of the computer. Now serverwmc live tv is working, but what can be done with it? I don't see it in MediaBrowser on my computer or android app. Glad I could help.
AgileHumor 123 Posted January 26, 2014 Posted January 26, 2014 localhost also did not work for me, connected OK after entering the static IP.
nicko84 72 Posted January 26, 2014 Posted January 26, 2014 Hi ! MB3 Server is always running BEFORE ServerWMC starts....so LiveTV can't connect. Have you a trick to run Server WMC BEFORE MB3 Server starts please ? Thanks for your help !
swhitmore 781 Posted January 26, 2014 Posted January 26, 2014 Hey guys, I couldn't get the plugin to connect to the ServerWMC either. I've installed it on my HTPC (different for the server), and tried the computer name and IP with no luck. I've added the ports to my firewall on both the server and HTPC with no luck. I just keep getting the error "CONNECTION FAILED". ServerWMC LogMB Server LogChecked netstat and it's definitely listening.
WWWestern 94 Posted January 26, 2014 Posted January 26, 2014 swhitmore, аnd is on HTPC, where was installed ServerWMC, also is installed MCE and configured channels and EPG?
swhitmore 781 Posted January 26, 2014 Posted January 26, 2014 (edited) swhitmore, аnd is on HTPC, where was installed ServerWMC, also is installed MCE and configured channels and EPG? Yeah, I use WMC on the HTPC for live TV already. Could PlayReady be causing issues? Edited January 26, 2014 by swhitmore
jcain 7 Posted January 26, 2014 Posted January 26, 2014 Hi ! MB3 Server is always running BEFORE ServerWMC starts....so LiveTV can't connect. Have you a trick to run Server WMC BEFORE MB3 Server starts please ? Thanks for your help ! You need to make serverwmc into a service with srvstart, then make a scheduled action to watch serverwmc being started and have it launch mb server at that operation
WWWestern 94 Posted January 26, 2014 Posted January 26, 2014 You need to make serverwmc into a service with srvstart... Why not use C:\Program Files (x86)\ServerWMC\InstallService.bat ?
WWWestern 94 Posted January 26, 2014 Posted January 26, 2014 Could PlayReady be causing issues? PlayReady PC Runtime is installed for me.
WWWestern 94 Posted January 26, 2014 Posted January 26, 2014 For experiment I uninstall PlayReady but Live TV works as before.
BATTLE DONKEY 98 Posted January 26, 2014 Posted January 26, 2014 Have u tried going to the scheduled tasks and refreshing the guide. I had the same issue where under the live tv tab it said serverwmc was not connected even tho the serverwmc application was picking up all my channels and tuners. Once I refreshed the guide everything sorted itself out n was up and running
swhitmore 781 Posted January 27, 2014 Posted January 27, 2014 Have u tried going to the scheduled tasks and refreshing the guide. I had the same issue where under the live tv tab it said serverwmc was not connected even tho the serverwmc application was picking up all my channels and tuners. Once I refreshed the guide everything sorted itself out n was up and running Thanks, I just tried that, but still getting the same connection failed error.
swhitmore 781 Posted January 27, 2014 Posted January 27, 2014 (edited) Ok, so I've tried changing ports, firewall settings etc. Still no luck. Am I the only one? @@krustyreturns any chance you can take a look at this? Edited January 27, 2014 by swhitmore
nicko84 72 Posted January 27, 2014 Posted January 27, 2014 You need to make serverwmc into a service with srvstart, then make a scheduled action to watch serverwmc being started and have it launch mb server at that operation Thanks for your help ! I will try this...but developers have to find a better way to solve this problem...
scarecrow420 8 Posted January 27, 2014 Posted January 27, 2014 FYI ServerWMC can run as a windows service already, no need to convert it using srvstart. Check the ServerWMC wiki. A previous poster in this thread had the right idea (InstallService.bat) So if I understand your problem correctly, you want MB3 and ServerWMC to start on windows start/reboot but you need ServerWMC to be running before MB3? I would suggest the order shouldnt matter (MB3 should keep attempting to connect to ServerWMC so when it is started, the connection is established). But if you do want to try and influence the start order, apart from the scheduled action suggestion you could also set ServerWMC (installed as a servie) to auto start, and MB3 service to autostart (delayed). that should ensure ServerWMC is started by windows, before MB3 is
robsch 45 Posted January 27, 2014 Posted January 27, 2014 Ok, so I've tried changing ports, firewall settings etc. Still no luck. Am I the only one? @@krustyreturns any chance you can take a look at this? Do you happen to have WMC running (ie. open) One thing I found, which I thoguht was odd, and it might just be due to my hardware is that if I had WMC, then when I connected with MB3 to ServerWMC, I would see it, be able to see the guide, but not tune into any station. Once I shut down WMC, and restarted ServerWMC, it would work like a champ. - Robert
nicko84 72 Posted January 27, 2014 Posted January 27, 2014 FYI ServerWMC can run as a windows service already, no need to convert it using srvstart. Check the ServerWMC wiki. A previous poster in this thread had the right idea (InstallService.bat) So if I understand your problem correctly, you want MB3 and ServerWMC to start on windows start/reboot but you need ServerWMC to be running before MB3? I would suggest the order shouldnt matter (MB3 should keep attempting to connect to ServerWMC so when it is started, the connection is established). But if you do want to try and influence the start order, apart from the scheduled action suggestion you could also set ServerWMC (installed as a servie) to auto start, and MB3 service to autostart (delayed). that should ensure ServerWMC is started by windows, before MB3 is Yes that's it ! To start ServerWMC BEFORE MB Server is running you have to : First, you run"install.bat" in "C:\Program Files\ServerWMC" to install ServerWMC as a Service (with autostart) Than you chose to start MB3 Server as a Service too (and not to start it with Windows) AND you modify the MB3 Service from autostart to autostart (delayed). Thanks for your help !
