steelman1991 19 Posted January 25, 2014 Posted January 25, 2014 No that's the whole purpose of using Reclock to obtain bit-perfect WASAPI audio. The only thing you don't get is the little 'Dolby or DTS' symbols lighting up on your receiver.
AVTechMan 8 Posted January 25, 2014 Posted January 25, 2014 Ah okay, I will give ReClock a try. Doesn't matter about the 'lights' on the receiver that much, whether its multichannel or direct bitstream as long as I get the audio that's meant to be heard.
babgvant 143 Posted January 25, 2014 Posted January 25, 2014 Where would I download this patch? As to the workaround, I don't understand exactly how to do this, diabling the bitstream, configure for 5.1 speaker setup does not give me 5.1 pcm, but rather stereo pcm. You'd have to build MBT yourself to get the patch. You don't need to use Reclock to get multi-channel PCM out. Just go to the "Sound" control panel config and configure your speaker setup correctly. PCM audio will get touched by the Windows Mixer though so a WASAPI renderer is a better option (bit perfect and proper channel matching) long term, but it's not absolutely necessary.
swhitmore 781 Posted January 26, 2014 Posted January 26, 2014 Hey, I'm having the same issue. Let me know if you would like me to test.
warwon 0 Posted January 26, 2014 Author Posted January 26, 2014 I just went back t Ultima Dragon since 1997
warwon 0 Posted January 30, 2014 Author Posted January 30, 2014 Confirmed last night build or whenever it was fixed bit streaming and is working fine. Haven't tried a dts-hd source yet Ultima Dragon since 1997
lorac 119 Posted January 31, 2014 Posted January 31, 2014 I still do not get anything better than PCM when playing a DTS or higher source.
Yogi 367 Posted January 31, 2014 Posted January 31, 2014 Bitstreaming is working for me,just played a DTS source via HDMi option and all good. The only problem is when you select the option in video player it doesn't stick,so when you restart MBT you have to select the option that you want (HDMI or SPDIF) again. But other than that as I said all working good.
lorac 119 Posted January 31, 2014 Posted January 31, 2014 OK. That works. Somewhat annoying, but better than nothing
babgvant 143 Posted January 31, 2014 Posted January 31, 2014 Can you check you system.xml to see if the value is persisted after changing and exiting the config page? I can't reproduce that issue here.
Yogi 367 Posted January 31, 2014 Posted January 31, 2014 Just fired up MBT and it looks as though it is now saving the setting that I chose,so it is working as expected.
AVTechMan 8 Posted February 2, 2014 Posted February 2, 2014 I can verify that TrueHD and DTS-MA bitstreams now, but regular DD still doesn't bitstream unfortunately for the DVD movies.
babgvant 143 Posted February 2, 2014 Posted February 2, 2014 You can't bitstream TrueHD and not bitstream DD w/ LAV. You have to enable the base format for the HBR version of the same type to work. Are you sure you selected the correct audio track for the DVD?
AVTechMan 8 Posted February 2, 2014 Posted February 2, 2014 You can't bitstream TrueHD and not bitstream DD w/ LAV. You have to enable the base format for the HBR version of the same type to work. Are you sure you selected the correct audio track for the DVD? I'm sure. The DVD files bitstream the DD just fine using just MPC-HC in MBC w/LAV. All of the formats have been checked in the LAV settings for bitstreaming in MBT. Now If I turn off bitstreaming in MBT then the audio in the file plays fine via internal decoding. I'll work with it again a bit later. All of the files are MKV.
babgvant 143 Posted February 2, 2014 Posted February 2, 2014 Maybe DVDs follow a different code path. I'll have a look.
babgvant 143 Posted February 3, 2014 Posted February 3, 2014 Please enable debug logging then play a DVD with an AC3 track and search the log for "bitstreaming:" (no quotes when you search). MB will enumerate all of the bitstreaming formats and their status.
AVTechMan 8 Posted February 4, 2014 Posted February 4, 2014 (edited) Ok I will work on that. Edit--forgot to ask, how do you access the debug log for MBT? Edit II: Now this is weird...I took MBT out of full screen and have it windowed, and now the DD is bitstreaming . When I go back to fullscreen it doesn't bitstream (no audio). This is odd indeed..... Okay, when I move back and forth in the file, it looks the DD bitstream eventually catches. It seems that it takes a good moment for my AVR to switch to the bitstream, otherwise it doesn't play any audio. I'm going to have to work on this one, but I still need to know how to access the debug log. Edited February 3, 2014 by AVTechMan
babgvant 143 Posted February 4, 2014 Posted February 4, 2014 I'm not sure where the log is written when you do a normal installation (I've only run it from my git repro), but the logs are stored in "MBTFOLDER\ProgramData\logs" and named theater-somenumber.log so if they aren't in the MBT folder, maybe search the real ProgramData for "theater-".
Taobear 0 Posted February 5, 2014 Posted February 5, 2014 I am having the same issue here. Media Browser Theater version 3.0.5129.37166 is currently installed. Movies with DTS Surround will play without problems - it is recognized by my Denon AMP via HDMI from my Graphic Card. Some movies which only have AC3 (5.1) will show only Stereo in the AMP. Bitstreaming in MBT is activated. Weird is - when I run the same movie with Windows Media Player, then my AMP display Dolby Digital in the display. In the Theater-xxxxxx.log File I found the following entry for this issue. (This series has AC3 according to the File Information and it is also displayed as 5.1 in MBT) 2014-02-05 20:16:31.9355, Info, DirectShowPlayer, Playing The High Road. Reclock: False, Madvr: False, xySubFilter: False2014-02-05 20:16:31.9355, Info, DirectShowPlayer, Playing Path N:\Series Old\Person of Interest\Season 2\Person Of Interest - S02E06 - The High Road.mkv2014-02-05 20:16:32.1211, Error, DirectShowPlayer, Error adding LAV Audio filter Unspecified error System.Runtime.InteropServices.COMException at DirectShowLib.DsError.ThrowExceptionForHR(Int32 hr) at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableReclock, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) Playing a file where I can use DTS Surround - the following information is in the Log File. (This series has DTS according to the File Information and it is also displayed as 5.1 in MBT) 2014-02-05 20:34:34.1053, Info, DirectShowPlayer, Playing Broken Bow (1), Broken Bow (2). Reclock: False, Madvr: False, xySubFilter: False2014-02-05 20:34:34.1053, Info, DirectShowPlayer, Playing Path M:\Series New\Star Trek - Enterprise\Season 1\Star Trek, Enterprise - S01E01-E02 - Broken Bow (1), Broken Bow (2).mkv2014-02-05 20:34:34.1733, Error, DirectShowPlayer, Error adding LAV Audio filter Unspecified error System.Runtime.InteropServices.COMException at DirectShowLib.DsError.ThrowExceptionForHR(Int32 hr) at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableReclock, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter)
babgvant 143 Posted February 5, 2014 Posted February 5, 2014 2014-02-05 20:16:32.1211, Error, DirectShowPlayer, Error adding LAV Audio filter Unspecified error System.Runtime.InteropServices.COMException at DirectShowLib.DsError.ThrowExceptionForHR(Int32 hr) at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableReclock, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) Something has gone wrong with adding or configuring LAV Audio. I will add some debug logging to figure out what. In the meantime you can 1) enable debug logging (if it's not already) 2) make sure you have a recent version of LAV Audio installed.
Taobear 0 Posted February 5, 2014 Posted February 5, 2014 I have updated to LAV Version 0.60.1 already (previously used LAV Version 0.59.1) till now. The Debug Modus is already activated but the file is rather large. What I notice when I played the same file as above is that the LAV Splitter does not shown up in the Task compared to before. LAV Audio and LAV Video Splitter not show up at all there. I do get the same message when playing the file as above - in MBT it shows Stereo. in Windows Media Player, the same file started it shows Dolby Digital in the AMP Display. Anything else what you need to know, please feel free to let me know.
Getumzz 13 Posted February 6, 2014 Posted February 6, 2014 (edited) Remove my post Wrong thread Edited February 9, 2014 by MrDon
Taobear 0 Posted February 13, 2014 Posted February 13, 2014 Any update until now? Not want to push - but at least like to ask and pay attention. Thanks
babgvant 143 Posted February 13, 2014 Posted February 13, 2014 Any update until now? Not want to push - but at least like to ask and pay attention. Thanks I added logging so it will tell me where the problem is coming from, but you need to generate a debug log (and share it) for that to be useful.
Taobear 0 Posted February 17, 2014 Posted February 17, 2014 With the latest Version 3.0.5143.14952 it seems working again. I can play on the same movies / series as a couple of weeks ago now Dolby Digital and DTS too.
