Can't get Emby for Kodi to direct play
Ok. Thanks for all your help,
Sent from my XT1585 using Tapatalk
Angelblue05
Once this is resolved, I suggest you run a repair sync by launching Emby for Kodi, you can select by mediatypes and it should force refresh your incorrect paths with the correct ones.
Guest
