How can I test Kodi direct stream/transcoding from home?
I thought it was enough to get an own public IP for my PC I'm testing from. But it seems as I'm on the same local WAN Kodi can use direct play via DLNA? "Play from HTTP instead of SMB" is active but I guess it doesn't matter to DLNA.
Hmm, UPnP aka DLNA isn't even on in Kodi settings.
Ah, there was DLNA settings in Emby server settings...
Edited by imoryle
Angelblue05
The addon and dlna are two separate things. They have no influence on each other.
The addon syncs your content to Kodi, and this is what is effected by the play from HTTP setting.
Sent from my iPhone using Tapatalk
Edited by Angelblue05
Guest
