Luke 42237 Posted November 23, 2016 Posted November 23, 2016 There has been a lot of volatility on the dev channel but it is starting to clear up. Here's a new build you can play with. Thanks for trying it out. Emby.Server.Mac.zip
tgmcpa 0 Posted November 25, 2016 Author Posted November 25, 2016 Thanks, I appreciate all you are doing. I really want this to work, so I'm happy to help any way I can. Did the complete uninstall, installed the new release, and it got farther, but the library scan still failed. The error it keeps throwing is "input string was not in a correct format". Log file attached... Thanks again, hope you had a great Thanksgiving holiday ! Tom server-63615542400 copy.txt
Luke 42237 Posted November 26, 2016 Posted November 26, 2016 Thanks ! Please try this build. Emby.Server.Mac.zip
Luke 42237 Posted November 28, 2016 Posted November 28, 2016 Here's an update you can play with. Thanks. Emby.Server.Mac.zip
Randy Kerr 0 Posted November 29, 2016 Posted November 29, 2016 I have Windows 10, and have, also, had several frustrating days of library scan fails: "Invalid Unicode code point found at index 11. Parameter name: strInput" I attached the relevant log section. Updating emby server had no effect. Help! thank you, Randy emby_error.txt
Luke 42237 Posted November 29, 2016 Posted November 29, 2016 I have Windows 10, and have, also, had several frustrating days of library scan fails: "Invalid Unicode code point found at index 11. Parameter name: strInput" I attached the relevant log section. Updating emby server had no effect. Help! thank you, Randy Hi Randy, I'm resolving this issue for the next release of Emby Server, thanks ! It will be in tomorrow's beta if you would like to try that. Keep in mind the beta is a work in progress and the upgrade experience might not be seamless at this stage.
tgmcpa 0 Posted November 29, 2016 Author Posted November 29, 2016 Luke The file you posted on 11/26 did allow the media library scan to complete successfully. The scan took over 36 hours, but it did complete. I'm slowly adding plugins, one at a time, to see how that works. I'll keep you posted if anything misbehaves. Thanks again for all your help, and your work on this ! Tom
Luke 42237 Posted December 4, 2016 Posted December 4, 2016 @@tgmcpa here's a new build you can play with. Emby.Server.Mac.zip
Luke 42237 Posted December 18, 2016 Posted December 18, 2016 The new release is on the website. To anyone who installed these testing versions, I would suggest installing the stable release on top of your existing version. Thanks.
