secagratis 21 Posted November 12, 2016 Posted November 12, 2016 Hello everyone a problem when I click on the player does not give me the film chose to start the exact one I have to click on the arrow at the top right.
Luke 42186 Posted November 13, 2016 Posted November 13, 2016 Hi, if you scroll down to the bottom of the page, what is the video file path and media info? does that match what was played?
secagratis 21 Posted November 13, 2016 Author Posted November 13, 2016 (edited) if you flow until the end comes out the selected video but I want to leave now Because the Android browser will not come out the arrows Edited November 13, 2016 by secagratis
Luke 42186 Posted November 13, 2016 Posted November 13, 2016 No, not in the video player. I mean in the first screen, scroll to the bottom of the detail screen. what is the video file path and media info? does that match what was played?
secagratis 21 Posted November 13, 2016 Author Posted November 13, 2016 it corresponds there are I would not want the film that did not find me and make confusion
ebr 16307 Posted November 13, 2016 Posted November 13, 2016 By any chance did you turn on the Cinema Mode feature and point it to some part of your library?
secagratis 21 Posted November 13, 2016 Author Posted November 13, 2016 By any chance did you turn on the Cinema Mode feature and point it to some part of your library? me a picture to figure out where is this option thanks
secagratis 21 Posted November 13, 2016 Author Posted November 13, 2016 you're right I had activated the cinema option now and everything ok thanks
Luke 42186 Posted November 13, 2016 Posted November 13, 2016 Thanks for confirming ! You don't need to turn cinema mode off, perhaps just try adjusting the path you've specified for custom intros.
