rliepins 9 Posted November 12, 2016 Posted November 12, 2016 Hello I am looking for a how-to on how to do a full reinstallation. I have installed the Configuration Backup plugin, but I don't know how to do a restore once I wipe and reinstall Emby Server. Is there a how-to on doing a clean uninstall and reinstall with the backup recovery? To head off the eventual question, the reason for a reinstall is that I have upgraded on top of my server for several years, even since the MediaBrowser 2.x days. I just want a fresh and clean slate. Thanks
Luke 42252 Posted November 12, 2016 Posted November 12, 2016 Hi, welcome ! What you can do is uninstall completely, then install the backup plugin and use the backup plugin config screen to restore from a saved backup. Let us know how it goes!
StLDreiling 16 Posted December 15, 2016 Posted December 15, 2016 Hello I am looking for a how-to on how to do a full reinstallation. I have installed the Configuration Backup plugin, but I don't know how to do a restore once I wipe and reinstall Emby Server. Is there a how-to on doing a clean uninstall and reinstall with the backup recovery? To head off the eventual question, the reason for a reinstall is that I have upgraded on top of my server for several years, even since the MediaBrowser 2.x days. I just want a fresh and clean slate. Thanks Did you go through with it? I'm curious about how your library is rebuilt following a clean install. I'm planning doing something similar (migrating to new hardware), so I'm planning on using Configuration Backup to restore users, plugins, settings, etc., but the backup directory doesn't seem to have a copy of the library database.
Luke 42252 Posted December 15, 2016 Posted December 15, 2016 Did you go through with it? I'm curious about how your library is rebuilt following a clean install. I'm planning doing something similar (migrating to new hardware), so I'm planning on using Configuration Backup to restore users, plugins, settings, etc., but the backup directory doesn't seem to have a copy of the library database. The backup plugin backs up your library folders and then runs a scan to populate the information into the new database.
ebr 16340 Posted December 15, 2016 Posted December 15, 2016 The backup plugin backs up your library folders and then runs a scan to populate the information into the new database. Just for clarification - it backs up the definition and configuration of your library folders. It doesn't back up your media....
StLDreiling 16 Posted December 15, 2016 Posted December 15, 2016 Just for clarification - it backs up the definition and configuration of your library folders. It doesn't back up your media.... lol thanks @@ebr, that's a good safety tip! This is brilliant, guys! Thanks! I'll let you know how it goes.
StLDreiling 16 Posted December 16, 2016 Posted December 16, 2016 Welp, I'm stuck. Logs attached. Log - 12.15.2016 - 2130.txt
Luke 42252 Posted December 16, 2016 Posted December 16, 2016 Can you please describe your issue in detail? Thanks.
StLDreiling 16 Posted December 16, 2016 Posted December 16, 2016 Sorry, Luke. New home for my Emby server. Skylake Core i3 quad-core processor, 16Gb DDR3L, 120Gb and 275Gb SSD. Windows Server 2012 R2 Standard w/ only storage-related roles installed. Fully updated, activated, joined to my network. .NET Framework 4.5.x and 4.6.x installed and updated. All library folders have been on network shares that remain unchanged.Ran Server Configuration Backup. Copied Premier key. Spun down "old" Emby (which is still 253).Verified unfettered access to network shares from new server, installed latest Beta build (256) on new box. Added application and port exceptions firewall. Ran "new" Emby's configuration wizard, adding only my account (w/ Connect) and no media libraries. Input Premier key so I could install the Backup plugin. Installed same (confirmed it was ver. 1.0.1.5, just as in the "old" Emby). Configured backup plugin to target network share w/ existing backups. List of recent backups populated without issue. Selected most recent to run and confirmed that I was "ok" with all existing data being overwritten. After a few moments, I was taken to what looks like a redirect page with the "new" browser favorite link. Weird. Left it alone for about 30 minutes. Saw no appreciable hard disk activity. Clicked the link, which was just to the server dashboard. No changes whatsoever from configuration restore. Same single user (me), no libraries/plugins/scheduled tasks, etc. Checked logs and didn't quite understand what the error was. Saw the event triggered and the location of the backup data restored accessed without issue. Thought it might be a network problem, so copied the backup set from the network share to a local drive on the "new" Emby server. Reconfigured the plugin to target the new directory. The backups populated, as before. Triggered a restore with the exact same result (only in place of the network shares, the local disk was accessed before the "access token is required" error was thrown). Those are the logs I provided.I wondered if this is some ownership/permissions thing. The user account that "new" Emby is running under is the same domain admin account that it was running under previously on the "old" server, and the directory attributes reflect that the account on the "new" Emby server is the owner w/ full permissions.
StLDreiling 16 Posted December 16, 2016 Posted December 16, 2016 I closed down my "new" Emby install and started up the "old" install again. I updated to the latest beta build and re-ran a configuration backup. I shut down the "old" server, spun up the "new," and attempted again to restore from the backup (thinking perhaps the version difference might've been a problem). Same result.
Luke 42252 Posted December 16, 2016 Posted December 16, 2016 I think the backup restore process just needs to be a little friendlier but you just need to restart the server after restoring from a backup.
ebr 16340 Posted December 16, 2016 Posted December 16, 2016 The restore used to automatically restart when it was finished. Does it not do that anymore?
StLDreiling 16 Posted December 16, 2016 Posted December 16, 2016 We get a prompt that the server will automatically restart after restore completes. That hasn't happened for me as yet, though I have no idea whether the restore actually began at all, or when it officially failed or finished if it did.I shut down the server, then started the server application up at 10:24 am. At 10:25, I triggered a manual Backup, just to see what it looked like. The Scheduled Task execution appears in the log, deleting the oldest existing backup due to the 5 backup max configuration (not a problem for me). I then triggered the restore of the backup data set I wanted (not the most recent manual "test" backup). I got the same prompts and was logged out of the web UI to the screen I mentioned earlier.I didn't log back in, but went to the Emby-Server folder to see if anything was happening. None of the files or directories showed any changes subsequent to me triggering the restore. I opened the log file, and the only activity recorded after the time I started the restore and was logged out were some DLNA notes two minutes later. From 10:28 to 10:36, nothing else had been recorded in the log. No errors this time. I previously created a new account with a unique name untethered to Emby Connect at this time. That seems to have solved the "access token" error message from earlier logs.But I don't see any activity - in the logs or within the Emby-Server directory - to suggest that the restore process has even begun. server-63617480678.txt
StLDreiling 16 Posted December 16, 2016 Posted December 16, 2016 I'm happy to help troubleshoot this if you guys are interested, but I wanted let you know that I opted to do a selective restore, bringing over only users and library info. It worked like a charm, faster and easier than I had expected. I'll do configurations, scheduled tasks, plugins, etc. on my own.
ebr 16340 Posted December 16, 2016 Posted December 16, 2016 If you can turn on debug logging and try it again at some point, that may help us figure out what went wrong. Thanks.
Happy2Play 9814 Posted December 16, 2016 Posted December 16, 2016 (edited) Tried to restore my beta over my dev install and few seconds after click okay I get "Please update your Emby bookmark to http://localhost:8096/emby/web/dashboard.html"do to redirect to "h ttp://localhost:8096/emby/ dashboard/dashboard.html", and nothing else. Same results trying to restore dev to a portable dev. Log only shows 2016-12-16 13:31:28.5052 Error HttpServer: Error processing request *** Error Report *** Version: 3.1.6185.27116 Command line: C:\Users\Media-Test\Desktop\Portable Dev\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Media-Test\Desktop\Portable Dev Application directory: C:\Users\Media-Test\Desktop\Portable Dev\System System.IO.FileNotFoundException: Unable to find the specified file. System.IO.FileNotFoundException No Stack Trace Available plugin 1.0.1.5 Edited December 16, 2016 by Happy2Play
