budssgc 5 Posted November 11, 2016 Posted November 11, 2016 Issue: Movies or any content is not being added to the library, Scan library finishes in seconds. The road so far, I have been using emby for about 6months or so with little to no problems.I built a new server to store all my data with different subnets for the emby server and file server, I decided to just rebuild emby from scratch with the new file paths and IP's. So i installed the newest version yesterday: Version 3.0.8500.0, Noticed some new things with the patch substitution, Configured everything and started to configure the media library, added my network paths and added the network share path, and ensured emby could see the path, and saved settings, Scan finished in seconds and every time i click scan library it finishes in seconds. But no media is showing up... Resolution = ? Emby Logs.txt
Luke 42186 Posted November 13, 2016 Posted November 13, 2016 Hi, welcome ! Thanks for the report. Yes if you could elaborate that would be very helpful, if something went "bad" then perhaps it can be detected and handled more gracefully. Thanks !
