goku2k 1 Posted November 11, 2016 Posted November 11, 2016 (edited) There are huge swaths of missing data in the guide data. From what I've seen most channels have "some" data, however virtually every channel is incomplete during most times. I use the same schedules direct login/lineup for a test build of SageTV, and it does not have the missing guide data (I only mention this to illustrate that the SD info should be correct). I am new to this community and this is a new build - so hopefully it is just something that I have overlooked. Also, something I didn't notice until I posted this topic - why is channel 712 out of order? (reference Guide_data_emby.png and Guide_data_emby2.png) Thanks in advance! Log.txt Edited November 11, 2016 by goku2k 1
ebr 16335 Posted November 11, 2016 Posted November 11, 2016 Check your guide sorting options (that grid looking icon).
goku2k 1 Posted November 11, 2016 Author Posted November 11, 2016 Check your guide sorting options (that grid looking icon). Ah, "Place favorite channels at the beginning" was checked - that explains 712 being out of order Thanks! Any suggestions for the missing data?
Luke 42242 Posted November 11, 2016 Posted November 11, 2016 Have you tried using the manual mapping function?
goku2k 1 Posted November 11, 2016 Author Posted November 11, 2016 Have you tried using the manual mapping function? I've looked over the mapping - and it looks correct. Also, if the mapping was incorrect wouldn't there be a complete absence of data? not just incomplete/missing sections?
goku2k 1 Posted November 12, 2016 Author Posted November 12, 2016 I tried changing zip-codes (to a nearby city that also has the same channel line up as my city), this too had the same results of large amounts of missing data. Is there anything that can be done? As mentioned in my original post, the same schedules direct lineup when used with sagetv does not have any missing data. This leads me to believe it is something with emby, or the way that emby is handling the data from SD.
goku2k 1 Posted November 13, 2016 Author Posted November 13, 2016 Is there *ANYTHING* else I can try? I'm even willing to try a new/different OS install if that is what it takes. I really like the interface for android and xbox one, and would VERY much like to use this - but unless the guide is fully populated, I'm afraid it won't be a very useful dvr system.
Luke 42242 Posted November 14, 2016 Posted November 14, 2016 I will review this soon. Thank you for your patience.
goku2k 1 Posted November 14, 2016 Author Posted November 14, 2016 I will review this soon. Thank you for your patience. Thanks, Luke! I look forward to your findings!
kanipek 230 Posted November 17, 2016 Posted November 17, 2016 There are huge swaths of missing data in the guide data. From what I've seen most channels have "some" data, however virtually every channel is incomplete during most times. I use the same schedules direct login/lineup for a test build of SageTV, and it does not have the missing guide data (I only mention this to illustrate that the SD info should be correct). I am new to this community and this is a new build - so hopefully it is just something that I have overlooked. Also, something I didn't notice until I posted this topic - why is channel 712 out of order? (reference Guide_data_emby.png and Guide_data_emby2.png) Thanks in advance! I am now seeing this exact behavior. I have just finished rebuilding my system. The guide was perfect until yesterday. Has there been any resolution to this issue? Odd thing is, it looks as if all the recordings are happening as scheduled. Pleas help! Thanks for reading, any and all help is appreciated.
goku2k 1 Posted November 17, 2016 Author Posted November 17, 2016 ... Has there been any resolution to this issue? ... I'm still experiencing it, too.
kanipek 230 Posted November 17, 2016 Posted November 17, 2016 This seems to be getting worse every time I reboot the server. I am attaching log files in case that might help figure this out. Thanks for reading and any help! server-63614939113.txt server-63614988186.txt
goku2k 1 Posted November 23, 2016 Author Posted November 23, 2016 Is there any update on this issue? If not, how do I request a refund?
Luke 42242 Posted November 23, 2016 Posted November 23, 2016 I am looking into this. I will setup a test environment with your schedules direct lineup. first, just to confirm. Does the Emby user you're testing with have any parental control options set?
goku2k 1 Posted November 23, 2016 Author Posted November 23, 2016 I am looking into this. I will setup a test environment with your schedules direct lineup. first, just to confirm. Does the Emby user you're testing with have any parental control options set? Hi Luke, There are no parental control options set for my user.
goku2k 1 Posted November 23, 2016 Author Posted November 23, 2016 I updated my system (I'm running debian 8, so apt-get update && apt-get upgrade), after which emby-server would not load. I tried re-installing the beta release (apt-get remove emby-server-beta, apt-get install emby-server-beta), however emby-server would still not load. I then removed beta and re-installed the stable version (apt-get remove emby-server-beta, apt-get install emby-server). This allowed emby-server to load. I then performed a guide data refresh, after which the guide appears fully populated. I would be willing to write this off purely ignorance on my part, had someone else not experienced the same symptoms of missing guide data. Are there any other logs that could be provided that would help identify what went wrong so that others can either avoid the issue I experienced, or if they do experience it - know what needs to be done to resolve? It really bugs me when things just start working without understanding why they started working (I'm not complaining that it's working - rather that I would like to understand *WHY* it started working).
Luke 42242 Posted November 23, 2016 Posted November 23, 2016 Thanks for the report. There are breaking changes in the beta channel we are still working out. As far as any it is working, it could have been some intermittent schedules direct failure that would have cleared itself up over time via the guide refresh. That or some other setting that might be causing a conflict although parental control is all I can think of right now.
