Johnny_x 0 Posted November 11, 2016 Posted November 11, 2016 Hello!few days ago I reinstall my home media center and after that, emby cannot read backdrops and folder structure, in attached pictures, sceenshot from my metadata manager and how looks in emby
Johnny_x 0 Posted November 11, 2016 Author Posted November 11, 2016 Please post a server log. here all logs https://1drv.ms/f/s!AqRsBak5Zpm0nEYppTgTqaY_Ri3Z
ebr 16307 Posted November 11, 2016 Posted November 11, 2016 How did you define your library and what is the structure of the file system (looks like an old mixed-content type of setup)?
Johnny_x 0 Posted November 11, 2016 Author Posted November 11, 2016 file structure Movie folder [movie name (year)] Movie pictures (backdrops, etc) others fles
ebr 16307 Posted November 11, 2016 Posted November 11, 2016 Please show us how you setup your library (how did you define it in the server) and a screen shot from explorer showing the actual directory/file structure. Thanks. You can also just make sure it conforms properly to one of the supported conventions.
Johnny_x 0 Posted November 11, 2016 Author Posted November 11, 2016 my movies is on 3 disks E: F: G: on root dir
ebr 16307 Posted November 11, 2016 Posted November 11, 2016 Try moving them out of the root. Create a folder called "Movies" (or whatever) and move them all under there. Then point your library at the Movies folder on each drive.
