nurgle 3 Posted November 11, 2016 Posted November 11, 2016 Hi, I'm having a bit of a problem with library scanning seemingly getting stuck at around 10%. Everything has been fine for a long time but all of a sudden library scans are not working so no new content is being added to my libraries even with real time monitoring turned on. I've attached a server log with debugging turned on. I've removed all plugins and turned off real time monitoring for now to see if a scan will complete but it just stays at 10.6%. I can't see anything in the log to point to the cause. If I try and stop the scan it doesn't, it just stays at stopping until I stop and start the emby service. The Mono process is also at 100% all the time while the scan is in process. I've left it scanning for more than 24 hours and it doesn't seem to get any further. Is there any way to see what it's doing while it's scanning? Or anything else that might stop it from completing. I'm pulling my hair out, i don't really want to delete my libraries and start again if I can at all help it. Many thanks, Nurgle server-63614450543.txt
nurgle 3 Posted November 11, 2016 Author Posted November 11, 2016 (edited) Well after 24 hours of trying and failing, as soon as I post on the forum it finishes a scan. Sorry for wasting anyone's time! OK well after a server restart it's hanging on library scan again, not adding anything new to the library. Stuck at 10.6% and process at 100% CPU again. I'm at a total loss. Any help would be appreciated. Edited November 11, 2016 by nurgle
Nem 2 Posted November 13, 2016 Posted November 13, 2016 Ive been having the same problem for about a month now Library scanning starts and usually gets stuck at around 27%. Restarting doesnt solve the issue. The only thing thats been allowing scan to complete lately is when a new emby (docker) update comes out. After the upgrade to the new version library scan succeeds once. After that it gets stuck again...
Luke 42244 Posted November 14, 2016 Posted November 14, 2016 There's an issue that's been identified with the library scan and music libraries causing it to get stuck, and this has been resolved for the next release of Emby Server. The workaround for now is disabling the music brainz metadata provider for albums and artists. Thanks.
Nem 2 Posted November 18, 2016 Posted November 18, 2016 I dont think thats the (only) cause of the problem. Ive disabled the provider you mentioned and it still gets stuck. I also dont have any music libraries in my collection
sualfred 677 Posted November 22, 2016 Posted November 22, 2016 (edited) If you have the Kodi QuickSync plugin enabled -> delete the Emby.Kodi.SyncQueue.1.X.ldb in /var/lib/emby-server/data/SyncData/. Don't forget to restart emby afterwards. I'm facing this issue sometimes and noticed that this file is causing the issue. Edited November 22, 2016 by sualfred 2
Nem 2 Posted November 24, 2016 Posted November 24, 2016 that seems to have fixed it for me. I just uninstalled the plugin. thanks!
nurgle 3 Posted November 24, 2016 Author Posted November 24, 2016 It's been fine for me too since removing Kodi QuickSync plugin.
Luke 42244 Posted November 24, 2016 Posted November 24, 2016 Interesting, thanks for reporting back. Please also try again with the next release of Emby Server as the scan will be much lighter. Thanks !
sualfred 677 Posted November 25, 2016 Posted November 25, 2016 (edited) Interesting, thanks for reporting back. Please also try again with the next release of Emby Server as the scan will be much lighter. Thanks ! I'm just guessing, but I think it's a Kodi Krypton<->FastSync issue. Afaik Krypton has a lot of music DB changes and I assume that will trigger a "loop" somewhere. The music DB sync works at the first time but after some days it's causing the same issue again. Some other people reported that disabling the Emby music db in the plugin did the trick. In my case I simply deactivated the FastSync feature and everything is fine. Everyone of us knows that Krypton is not officially supported, but since all major changes are done and the currently Betas are nearly a RC, everybody is switching to Krypton. Edited November 25, 2016 by sualfred
nurgle 3 Posted November 25, 2016 Author Posted November 25, 2016 I agree there's something not quite right with the Emby for Kodi with music sync on Krypton. After 1st sync I've stopped syncing music altogether and it's speeded up no end otherwise it can take 20 minutes at a time instead of seconds.
Nem 2 Posted November 25, 2016 Posted November 25, 2016 I'm not sure this is a krypton specific problem. I'm running openelec (kodi v15.2 isengard) on my raspberry pi and I was getting the problem above
sscheib 11 Posted November 25, 2016 Posted November 25, 2016 For me it's still stuck at 10%, even with removing the Kodi Sync Plugin
Luke 42244 Posted November 27, 2016 Posted November 27, 2016 Thanks for the report. Please try again with the next release of Emby Server. Thanks.
Luke 42244 Posted November 27, 2016 Posted November 27, 2016 The next stable, or latest beta if you're using that.
Luke 42244 Posted November 30, 2016 Posted November 30, 2016 We try to avoid ETA's. The best way to help get it released faster would be to spin up a test environment and help report issues against the beta. Thanks !
sscheib 11 Posted November 30, 2016 Posted November 30, 2016 I updated to the latest beta release, however now its stuck at 10.9%. Also I need to mention, that it continuously keeps requesting read access to various folders on my server (I'm currently running ACD (Amazon Cloud Drive) in debug mode, that's why I see it), but it doesn't go further on that library scan progress.
Luke 42244 Posted November 30, 2016 Posted November 30, 2016 Please always provide a complete server log. Thanks.
sscheib 11 Posted December 2, 2016 Posted December 2, 2016 Please always provide a complete server log. Thanks. Couldn't find a way to attach a non image file, so I uploaded it to pastebin. I turned debug logs on, but i can't see anything related to that issue. http://pastebin.com/gSJb2uNL I let it ran until now (which was around 15 minutes) and it was still stuck at 10.5%. Not other messages in the logfile besides that whatsoever
sscheib 11 Posted December 2, 2016 Posted December 2, 2016 I tried it with the latest version (ii emby-server-beta 3.1.242~beta-1733.1 all Emby Server is a home media server.). Or do you mean the next beta?
sscheib 11 Posted December 3, 2016 Posted December 3, 2016 new version same story - nothing new in the log files ...
Luke 42244 Posted December 3, 2016 Posted December 3, 2016 Can you please attach the complete log file? thanks.
