Vallefor 0 Posted May 11, 2019 Posted May 11, 2019 Wow, I am not alone. @@SamES Have the same problem. About 1-2 months ago play/pause stop working with tv remote. I have 3 chromecast (Chromecast 2015, Chromecast Ultra and Chromecast 2018) - none of them works with tv remote and Emby. It 100% worked before. I checked tv-remote with chromecast youtube app and it works perfectly fine.
SamES 1084 Posted May 12, 2019 Posted May 12, 2019 Yes, there's definitely an issue. It looks like the way we attached to the cec messages may not be working any more. I'm looking into it. Thanks
Raven 6 Posted May 15, 2019 Posted May 15, 2019 Discovered something odd tonight - CEC worked (play/pause) on .avi files but not .mkv or other more modern codecs. Not sure if that helps or hinders but there it is...
SamES 1084 Posted May 15, 2019 Posted May 15, 2019 Discovered something odd tonight - CEC worked (play/pause) on .avi files but not .mkv or other more modern codecs. Not sure if that helps or hinders but there it is... I've got a fix which we're just testing, but your comment did help as I need to test a transcoding file and you reminded me that avi files transcode on chromecast. Perfect! Thanks
Raven 6 Posted May 20, 2019 Posted May 20, 2019 I presume the fix has been deployed as CEC appears to be working again for me Yay!! Thanks for the quick fix
Batunga 6 Posted May 20, 2019 Posted May 20, 2019 CEC now also works again for me with Chromecast Ultra.
